#11 |
I'd do it for you Ryan. But man I'd have to charge you $850. It is about 16 hours worth of work and very labor intensive. But if 15-20 rwhp is worth it to you then do it. And while everything is off of the car you might as well spend an additional $$ for the powder coating. The only part of removing the cam covers that is not fun is removing the 4 nuts that hold the brake booster on. Once the brake booster is out of the way and that heat sink case bolted to the passengers side is out of the way your good to go. If you a fat man good luck squeezing down in the foot well to reach the the bolts lol! And take the seat out.
http://vid301.photobucket.com/albums...g/100_0014.mp4 |
#12 |
![]() Join Date: Jan 2010
He's right! Take the 10 minutes it takes to remove the driver's seat.
Makes it a lot easier. Not only that, I found a couple quarters under the seat! Didn't put much of a dent in the overall cost of the project though... |
