#11 |
My rear tires stand 26.7". That seems to be within the 4.5% stagger Phil states is within the operating range. Maybe go w a bit taller front tire.
#12 | |
![]() Join Date: Jan 2015
#13 |
![]() Join Date: Nov 2013
18mm.. that is a lot of spacer. hope you are running hubscentric billet spacers on that thing.
ed ramos #3028
EDRAM454 1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD. |
#14 | |
![]() Join Date: Aug 2013
http://tire-size-conversion.com/tire-size-calculator/ |
#15 |
Will it hurt anything if I just run it with the codes each time.
Will the ASR and ABS still work properly? |
#16 |
![]() Join Date: Dec 2005
im running the same sizes as Dom, and asr never showed up on mine
#17 | |
18mm is < 3/4". And yes running hub AND wheel centric spacer w GM Racing studs.
#18 | |
ed ramos #3028
#19 |
Mine are also billet, cost about $150 for the pair. Well made. They fit very snug onto the studs and center.
#20 | |
ed ramos #3028
