Old 03-16-2015   #11
secondchance
Default Re: Crankshaft Cup Plug Test
What can I say? Just heavenly that Phil is my neighbor. Being a part of WAZOO is the best thing that happened to my life long love affair with cars.
Old 03-17-2015   #12
Originally Posted by Scrrem View Post
Yes Hib, I recently did a 380 stroker build with an offset ground crank. After the griding process, the crank was heat treated and I was unaware that the plugs had not been replaced. The heat treating process took all the tension out of the plug side wall. When my motor was fired up for the first time I blew out a rear plug with 60 psi of oil pressure. Phil assisted me in replace all the crank shaft plugs. This test was just to satisfy his natrual engineering curiosity on what kind of pressure that the plugs would stand up to.
Rich
Same thing happened to me after 10 mins of run time on the "First" 380. Solution is to weld the plugs in which is what was done. I suggest that is the way forward. I also shared that bit of info to the entire readership YEARS.....ago. For those that dont know the crank has two types of plugs. threaded and Expansion plug style. It they were all threaded we would not have this issue. However I suggested welding the plugs like Kevin Pietro suggested (Who built my motor) but it looks like Phil also has a way forward. Your mileage may vary
Old 03-17-2015   #13
I don't understand what prompted this research?
Has there been instances of the crank plugs "blowing" out?
For us Folks that go WAY beyond the original design. Answer to second queston: Yes
Old 03-17-2015   #14
My warning on the crank plug in AUGUST 2012 !!!!!!! I wish I had put "380" in the search area beyond she lives however a lot of the registry members was following the build along at the time.
http://www.zr1.net/forum/showthread....ighlight=lives
