03-09-2015 | #11 |
Re: Simple oil question?
Read the back of a Mobil 1 15-50 container. Contains high Zinc content for high performance engines. Bought at Wally-world for $26 for a 5 quart container. A lot cheaper than amsoil. My $.02 worth.
03-09-2015 | #12 |
There are a few other Mobil 1 flavors that might suffice (come close to the "magic 1200/1300 numbers) if the 15/50 is not available: See Mobil 1 Product guide.
03-09-2015 | #13 |
Castrol GTX 10W-40 Diesel. Available in 5qt containers. $25
Been using it for 4 years w reground cams. Cam lobes look new.
03-09-2015 | #14 | |
You checked them recently? How do you know it is not your Marvel Mystery Oil
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-09-2015 at 02:32 PM. |
03-09-2015 | #15 |
Very funny Cliff. Actually, Marvel redeposited metal onto the lobes that were pitted and scored. They're just like new. And yes, Pete's regrinds. 2012-13 winter we added the exhaust cams.
03-14-2015 | #16 |
Wow...two really pervasive rumors in this thread.
1) Marvel Mystery oil "deposits" metal on camshaft lobes. A myth. 2) LT5s require engine oils with high zinc/phosphorous content Another myth. Insufficient ZDDP in engine oils is only an issue with flat tappet cams and pushrod valve gear. LT5 is OHC so 800 PPM phosphorous is plenty. The idea that you need an oil with 1000-1500-PPM phos or your engine will fail is ridiculous. Best oil to use in an LT5 for street high-performance and occasional tracking is an ester- or -mPAO based 10W30 synthetic. Such products are available from Gibbs Driven, Red Line, Amzoil and others and they'll all have 800-1100 phos which is plenty. Regular old Mobil One 10W30 is less expensive but, also, a good choice and it will have 600-800 PPM phos. if tracking the car all the time a 10W40 is better.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 03-14-2015 at 02:55 PM. Reason: spelling |
03-14-2015 | #17 |
I will cancel my order for a Case of Marvel Mystery Oil then
03-14-2015 | #18 |
I thought I had made that up. 😜
