03-06-2015 | #11 |
Re: Fuel Rail/Fuel Pressure Regulator
I love the current hat "style"
03-06-2015 | #12 |
The Topic is Fuel Rails......
Not Hats..... Wait a minute.......if the Topic is Jerry.....Hats Off To Jerry I could not survive without Jerry .....and that is NO JOKE That is a very nice Base Ball Cap for sure.......I would look good in that while holding some LT5 bolts. Say Jerry.....speaking of hats and bolts.....you will receive a Box full of Cam Cover bolts on Monday.....just send me Hats (exactly like below) for whatever you think the Cam Cover Bolts are worth
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-06-2015 at 11:35 PM. |
03-07-2015 | #13 |
I have a fuel rail that needs rebuilt. Only because it was apart when I got the motor it's from.
Let me dig up a photo for ya
03-07-2015 | #14 |
Jerry,
Brings hats for sale to BG. I'd like one.
03-08-2015 | #15 | |
Fuel Rail/Fuel Pressure Regulator and Caps
Me also on the current Hat style (Jerry's) But I see NO finger smudges on the Hat Bill of your hat that might indicate some original bolt handling or other mechanic work I have a case of Simple Green Spay bottles and Paper Towel nearby maybe like you do
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-08-2015 at 09:17 AM. |
04-11-2016 | #16 | |
Please help me make sense of what's happening to me. What were the symptoms your Z was experiencing? What was the car doing that made you look into the pressure regulator? Thank you so much! |
04-11-2016 | #17 | |
Apparently the air controlled valve/bellows totally failed with raw gas being forced out through the vacuum port and sucked into the Plenum from the Fuel Rails. Fuel coming out of the Vacuum Port on Fuel Pressure Regulator indicates a failure of the "bellows"/valve. Just hard to find a Fuel Pressure Regulator. |
04-11-2016 | #18 |
I've run into this issue a couple times myself.
Nothing you can do with the failed regulator but replace it with a good one. Expect we will be seeing more occurances of this failure as the fleet ages. Hope Jerry is working on a replacment for us before all the stashed OEM spares are used up.
04-12-2016 | #19 |
Please tell me the pressure regulator can be replaced without pulling the plenum!!
04-12-2016 | #20 |
Don't throw the old regulators away. The replacement, when my inventory is gone, will probably be an adjustable rebuilt core.
