Old 02-19-2015   #11
Default Re: Psycho III: LT-5 Opel w/LT-5
off the crank, lots of photos in HOB
Old 02-20-2015   #12
SAM/CH ZR-1
Is that a nose trigger or using stock reluctor wheel? Looks like it still runs in waste spark.
Behind the front harmonic balancer is a ignition wheel installed.
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
Old 02-21-2015   #13
rkreigh
Originally Posted by Tony Davila View Post
Why does it sound different than an LT5 even though I know it is an LT5?
the flat plan crank is what is causing the different sound along with whatever exh they crammed in this thing
Old 02-21-2015   #14
SAM/CH ZR-1
The crank is stock. The car on the video even run with stock pistons and stock cams. After the race season some pistons were broken.
Sam
Old 02-21-2015   #15
Sam,
How many teeth on the reluctor?
Old 02-21-2015   #16
SAM/CH ZR-1
Sam,
60-2 teeht. The researches and experiences we do with this project and the new parts (single trottles, injector housings etc.) are interesting and can open doors to build stronger performing big cubic LT5's. Right now I work on a 433cui LT5 and consider to overtake the new designed and machined single trottles and steel cams with a unusual duration and lift.
Sam
Old 02-21-2015   #17
Sam,
Not to take this thread too far afield, but I have wondered how much of an impediment the LT-5 ignition is to making more power. I was able to run my motor using individual LSx coils, albeit for 30-45sec. but the idle was noticeably smoother.
