Old 11-28-2006   #11
Phil DeJohn
Phil DeJohn's Avatar
Default Re: Any 10 seconds NA ZR1's out there?
Originally Posted by Zr1 Destroyer
Nice video....was that Will in his LPE415???
Not Will, ME.With a LPE-415.
Titusville FL.
Phil DeJohn is offline   Reply With Quote
Old 11-29-2006   #12
Kevin
Kevin's Avatar
I've determined I need to go to the Phil DeJohn school of driving. Phil, how do you do it
Old 11-29-2006   #13
Kevin
Kevin's Avatar
Originally Posted by Hammer
Dwight, can you answer this? I know you are at 700HP now.
7xx at the crank, I think he dynoed at 585ish at the wheels
Old 11-29-2006   #14
Zr1 Destroyer
Zr1 Destroyer's Avatar
Sorry man...his is the only one i've seen like that, nice run....looks like you got pretty good to, what was your sixty foot and coil overs or stock springs.
Zr1 Destroyer is offline   Reply With Quote
Old 11-29-2006   #15
Zr1 Destroyer
Is the white one SW's old car?
Old 11-29-2006   #16
Kevin
Kevin's Avatar
I meant dwights 415 dyno #'s....i don't know about the white car
Old 11-29-2006   #17
Phil DeJohn
I Don't leave hard, 2800 to 3000 rpm, 18x 60 foot. At about 30 feet on the floor and never lift till the end. I have coil overs.
Titusville FL.
Old 11-29-2006   #18
Zr1 Destroyer
Nice, a 1.8 short time for a monster 415 is great! When you say you never lift...automatic tranny or are you slammen gears with the pedal to the wood at all times? Rod(nj), to me for a ride in his new 07z06 and was banbibg gears and never lifting off the gas pedal...works pretty good!
I just got som HRE 16" wheels that are 11x16, so i'm going to try a Hoosier quik time Pro 28x11.5x16....hopefully this will work better than the BFG drag radials i've used in the past(1.9 60ft best)!
Now who's white Zr1 is that in the other vid.....SW......or the new owner???
Ry Beckloff
Old 11-29-2006   #19
Phil DeJohn
Ry Beckloff
Slammen gears with the pedal to the wood. That's SW's white car with him driving when he owned it. Will's car is a high 50 low 60 car, He's got bigger cams.
Titusville FL.
Old 11-29-2006   #20
guinnessdood
guinnessdood's Avatar
I don't know who's this is, but it's pretty stout too.
http://videos.streetfire.net/search/...52002dee64.htm
Did you see this WANNABEE!?!?!?!
http://videos.streetfire.net/search/...590103a899.htm
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
