Old 11-25-2006   #11
petefias
Default Re: Minor rear hight adjustment how to please?
Originally Posted by jonszr1
t5hanx again for your help .got it dialed in. I put a floresent mark on the car on the spots where I measured. have to use a black light to find em , but don't have to measured. On the lowering I amgoing to wait till i get the whole kit . I am toying with just taking it to gulstrand. I hear he does quality work. I nhear the front spring can be a bear . What is a safe amt to lower the car? again thanx for all your help
It really is a question why you want to lower it. If you're after great handling you probably benefit more from coil-overs or at least harder springs, urethane bushings, revalved shocks. If you're after the looks than you can lower it as low as you can stand it (and not scrape on crossing yellow lines).
The front lowering with leaf spring requires the removal of the spring and it is not a 10 minute job. It is doable on jack stands but it will take time.
I think 1" lowering is a good compromise. More than that will make you scrape a lot. Some cars ride higher than others so on those you could lower a little more.
Old 11-25-2006   #12
jonszr1
jonszr1's Avatar
thanx again.it really nice to meet helpfull people here. thats how I learn don't have time to be a book worm. I like the idea of 1in lower, yea its for looks. I am more of a straight line guy. would coilovers make a big dif in 60ft times. These cars are not easy to launch. how muchis it to do. is it something i can do or is it better to have done.? again thanx for taking the time to enlighten me
Old 11-28-2006   #13
petefias
I'm not much of a 1/4 mile guy, so couldn't advise on the effects of coilovers. It is doable on jackstands, but you need some expertise and tools. No clue what shops would charge on that.
I lowered mine about an inch front and rear. I played with it for a good part of a Saturday if I remember correctly.
