01-21-2015 | #11 | |
Re: Changing oil...Let it drain overnight ?
I have found that Camshaft bearings and rod bearings maintain oil for a very long time with engine not running (like years). The Lifters also maintain oil on their surfaces for a very long time as do the Cams. Likewise the Chain Guides maintain oil for a very long time. The Chain tensioners will bleed back oil but it has been said that Start Up Loose Chain guide slap is just a noise and no harm and no foul mechanically. Having said all that......pre-filling the filter definitely does not hurt the engine in any way
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-21-2015 at 01:08 PM. |
01-21-2015 | #12 | |
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 01-21-2015 at 02:39 PM. |
01-21-2015 | #13 | |
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-21-2015 at 02:52 PM. |
01-21-2015 | #14 |
So, do some filters let you pre-fill with oil, turn them upside down and the oil doesn't pour out (all the time while you're spinning it in place)?
Yesterday I bought a Napa Wix 1324 filter and will be changing my oil this week. It's hard to imagine not making a mess. I've always prefilled oil filters in the past, but I've never had a car with the OF on top of the engine upside down.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015) MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3 [IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG] |
01-21-2015 | #15 |
The best way to install a pre oil filled filter for the LT5 is to turn the car upside down, that way you won't spill a drop....I'll just leave it at that.....
01-21-2015 | #16 |
I could see just pouring enough oil into a new filter to saturate the filter media which might facilitate a quicker flow-thru when the flow of oil fills the empty filter can on start up. You could reasonably expect to be able to flip it and screw it on quick enough to not make a mess.
Plus if do it fast it will be a centrifuge of sorts and won't blurp out the threaded hole. Don't slip! |
01-21-2015 | #17 | |
01-21-2015 | #18 |
You guys.
01-21-2015 | #19 | |
01-21-2015 | #20 |
That's what happens. Flip it over fast enough and you won't spill any oil. You can just spin it on quick enough.
