Old 12-21-2014   #11
Mystic ZR-1
Mystic ZR-1's Avatar
Default Re: In car removal of cam covers
Got some of the stuff back from the PCer!
Couldn't resist sticking it together to see how its gonna look!
Cam covers are off without incident! To PCer after
the holidays.
Old 12-21-2014   #12
BigJohn
BigJohn's Avatar
What's that Black thing????
Old 12-22-2014   #13
Hib Halverson
Before you pull those covers, make sure you understand the procedure to properly seal them when you put them back on.
Also, DO NOT let the powder coater coat the underside of the covers. Any change in thickness of the cover will change camshaft being clearance.
The sealing surface of the covers must stay pristine or bearing clearance will be FUBAR.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 12-22-2014   #14
Billy Mild
What method did you use to remove the cam covers?
If I went through all this work I would definitely have my plenum ported while its off.
Old 12-22-2014   #15
Mystic ZR-1
A good rap with a drift and a hammer to the bolt heads (to get their attention...) and then use of a hand impact with a tight fitting torx socket to break them loose. All came out without buggering up the bolts or snapping any off.
That's some tough thread locker they used at the factory...
Old 12-23-2014   #16
BigJohn
BigJohn's Avatar
Why port the plenum and not the heads?
Old 12-23-2014   #17
Yup. A top end porting opportunity presents itself. However, to avoid messing up the paint job, it would have been better to port the plenum (and the IHs too perhaps) before the PC'ing was done (in case something has to be welded as result of punching through one (or more) of the plenum/IH runners).
Old 12-23-2014   #18
Billy Mild
I thought the heads flowed pretty well from the factory.
Old 12-24-2014   #19
Considering it is possible with a properly tuned motor with top-end porting and free flowing exhaust to get 390 to 400 wheel hp on stock cams - is a pretty good indication there is a LOT more horsepower to be had by letting it breath better.
Old 12-28-2014   #20
Mystic ZR-1
Cam covers going to the PCer next week.
How do you remove the secondary timing chain
guide strips?
Any special kind of wire to retain the new foam
filters during reassembly?
Thanks!
OBTW: not a single scratch in the guide strips!
