12-13-2014 | #11 |
Re: New 1990 ZR1 engine in crate
Four in ZR-1s and two on the floor
12-13-2014 | #12 |
Guess you can never have too many. Congrats.
12-31-2014 | #13 |
1991 LT5 with 36K miles
I now have one more
Just picked LT5 up today 1991 with 36K miles Including Bell Housing, Clutch, Pressure Plate, Flywheel. And including Oil cooler hoses, thermostat housing, and everything under Plenum. And also including the ECM (with chip) and Wire Harness.......and...and...also bought the Transmission. And some other stuff like the Cluster, Climate Control, and Bose (including the bezel and full power switch). Happy New Year
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-31-2014 at 10:05 PM. |
01-01-2015 | #14 |
Hoarder maybe???
I'm down with that!! More fun than bricks, glass insulators & Mason jars.
Jerry Downey [I][COLOR=#ff0000][B]JERRYS LT5 GASKETS & PARTS[/B][/COLOR][/I] [URL="http://www.jerrysgaskets.com"][U][COLOR=blue]http://www.jerrysgaskets.com[/COLOR][/U][/URL] 1994 [B][I]ZR-1[/I][/B], Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. |
01-01-2015 | #15 | |
Especially now that I figured out how to remove and install the LT5 with Headers attached. Like Plenum removal....got that down to 10 minutes which is also a lot of fun because now messing with the starter, coils, vacuum system is an hour job from start to finish and that is why I use NO Loctite on those Plenum Bolts and nothing on the Plenum Gasket (have TB coolant blocked at Injector Housing on ALL LT5s) I do not even torque the Plenum Bolts more than hand tight. I just check them once in a while to make sure they are not getting too loose (they stay tight using Stat-O-Seal washers with the rubber gasket). I check them when I am filling up with gas But then again.....after I mess with the starter, injectors, secondaries, and vacuum system the first time I am finding they function for ever perfectly. The LT5 is the most fun of any engine I have ever worked on for sure .
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-01-2015 at 01:00 PM. |
01-01-2015 | #16 | |
Your getting mellow in your old age Clint.
01-01-2015 | #17 | |
Cliff |
01-01-2015 | #18 |
Cliff, you're my new hero. Parts hoarders unite!!!!!
01-01-2015 | #19 |
Dang me, that's a lot o' motors.
