#11 |
![]() ![]() Join Date: Nov 2007
A very interesting topic! LEAN is a common enough occurrence with these cars to warrant a TECH article. A teensy bit to a major list, seems MOST have a little. I myself have dealt with it on my 95, and now I've got a wee bit on the Z. A comprehensive article would be oh so good. Brett????
![]() IF someone(s) want to PM me with the nuts and bolts (so to speak) of a process for leveling these cars, I will be more than happy to write it up (about all I can contribute to this topic, unfortunately). Any volunteers??
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 10-14-2014 at 07:34 AM. |
#12 |
I am about 1/2" higher on the passenger side. Seems like coil overs are the cure.
I personally hate that!
#13 |
![]() Join Date: Apr 2004
My 93 has 1/4 inch difference, higher on the right. The 91 was the same but I made an adjustment to the rear spring bolts (I have the longer bolts with the nylon lock nut) I had to tighten the left up about an inch to get it level.
I'm sure this may upset the cars stability in some way due to the torsional twist on the frame and I may not leave it. Note: All measurements were done to body panels and not to the FSM trim height locations.
#14 |
![]() Join Date: Oct 2013
Our 94 was a little higher on the right front before I installed the VB&P adjustable spring. With its threaded adjusters on each side,ride height on either side is easy to change & fine-tune. I also installed a pair of 11" long 14mm rear spring bolts that I purchased at my local Fastenal store,for $24/pair.
Presently have the front ride height at 26 1/2" and the rear at 27".
Clint & Sherry 1994 ZR-1 White/Red #152 (sold) 1991 ZR-1 Callaway Aerobody #1332 (sold) 1990 ZR-1 Red/Red #952 (sold) 2002 Z06 Torch Red/Mod Red widebody |
#15 |
With the stock setup (ie no front C5 style adjusters) if you lower the right rear you will primarily raise the left front - adjustment works in an "X".
HTH, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
#16 |
Well... I believe the issue is in the back; when i lowered the back the front lowered substantially. I went to Fastenall today in Conroe and thought I needed a 9" bolt, they only had 8" and 10".
Anyone know how long the stock bolts are? If the 10" will work I'll go back tomorrow and buy it. I know this is not the FIX, however, I think this will get me by and stop being so lopsided, mine leans a lot.
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
#17 |
![]() ![]() Join Date: Feb 2010
I believe you are only fixing a symptom of the real issue by experimenting with bolts. The lean is there for a reason.
Check that rear spring, especially at each of the center mounting area. There is a good chance that the spring is fractured and failing, which could lead to an unsafe condition. Food for thought.
#18 |
I absolutely get that, but i don't see/feel any issues externally..
#19 |
You may have to un-mount the spring to get a full inspection. You only have bushings and the spring itself that would cause this condition. Other than these items, you would have to have a suspension component failure happening.
Not sure if an internal rear shock failure would cause your condition.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 10-14-2014 at 07:38 PM. |
#20 |
![]() Join Date: Jul 2005
I had my rear torsion bar links and bushings replaced and it seemed to have leveled the rear.
JB 1990 #148 Red/Saddle Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice :cheers: |
