Old 09-27-2014   #11
BennieC.
Default Re: Injectors
Although all the injectors will satisfy the requirement for fueling, they also all have different electrical characteristics. Don't be surprised if the motor doesn't run the same way it did w properly functioning stock injectors. Idle and low speed performance will be affected the most.
That is so true. I am actually about to start working on my customers 1990 and I also informed him a slight misfire at idle. Did a current ramp test on primary and there is at least 1 injector bad. Didn't identify which injector since he declined the replacement at this time.
I also have another customer with a 1990 that is having a driveability concern on his modded 350. Took it out on a test drive with the owner and when decelerating from 70mph to 55 then accelerate, it would stumble for a second then accelerate normal. I told him I'm betting it's in the tune.
BennieC. is offline   Reply With Quote
