09-01-2014 | #11 |
Re: Few issues with my Z
Care of Marc Haibeck:
I believe if it is hunting like that, then one can assume the IAC is working; as the name implies, Idle Air Control: wouldn't "hunt" if it wasn't actively varying idle air flow - a scanner would be ever so handy here. However, the Throttle Position Sensor comes to mind. As it happens, just a few days ago I had removed the TPS connector temporarily as part of another project, and forgot to reconnect it before I fired it up. Same symptoms you describe - I think? When I fired it, the idle speed took off, settling at closer to 2100 rpm and it began to hunt a little. So, you admit your TPS is "bad", then that would be the place to start eliminating troubles, methinks.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 09-01-2014 at 08:48 AM. |
09-01-2014 | #12 |
I suspect the car in the picture is the car he wished he'd picked up 5 years ago.
I think I like the side pipes. |
09-01-2014 | #13 |
If you got a TPS CIRCUIT DTC, then maybe before buying a new TPS, plug in a multimeter with backprobes (paper clips) in the TPS harness connector, to test voltage.
Then if range of voltage with IGnition ON, motor off, is not correct, check resistance of the TPS itself. BASELINE: Range of motion pegged
09-01-2014 | #14 |
Tried deleting this after I realized it was pic of the 383 BigIke was describing.
