Old 08-28-2014   #11
Default Re: Imust be crazy!
You could write this story with a "fill in the blank" format so all of us could post it. How many 10min jobs turn into multi-day "goddamit should have left it alone"
stuff?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-28-2014   #12
Kevin
Kevin's Avatar
Dropped one of the screws that hold the map sensor once, no idea where it went. Dropped one of the screws that holds the fuel pumps to the rear deck, took 20 minutes to find it
Old 08-28-2014   #13
Scrrem
Scrrem's Avatar
Wow Yun. I think your car must be have a hex on it.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 08-29-2014   #14
Roadster
Roadster's Avatar
When I did the headlight gears this past weekend, undoing the RS unit, doesn't the lower left flanged nut drop into the twilight zone at the bottom of the air assembly, of course it does....... go figure......still haven't located it. When I went to HD to get a replacement torx screw, also picked some flanged nuts. All is good.
In my younger days when I had my first '74 (Coupe) I also would wash before work and had a bet with my brother who had a 63 SWC who would put on the most coats of Liquid Glass in one month. Of course I did and did it after work..
Am I crazy???? Just as crazy as you are and all of the other members here and enjoying every minute of it......
1974 LS4 454 Vert
1974 L-82 355 Vert.
