Old 08-26-2014   #11
tccrab
tccrab's Avatar
Default Re: Pulling the Plenum for the first time...
Originally Posted by Billy Mild View Post
The car runs a little rough at idle. The local guy seemed to think it ran really rough for a ZR1.
A properly running ZR1 will easily pass the "Nickel Test".
http://www.digitalcorvettes.com/corv...o/1413/cat/508
'Crabs
Old 08-26-2014   #12
Billy Mild
Not necessarily vac leaks...
It could be air getting by the 2' TB butterfly (which I suppose amounts comparably to a vac leak), but not entirely the same.
Cut a gasket withOUT cutting the 2' holes, to re-check idle quality. I did this, and idle was rock-steady. I'll put it back in, when I learn coding.
What would this prove? If it does prove anything how can it be fixed?
Old 08-26-2014   #13
Schrade
For starters, it can show that you have no vacuum leaks ELSEwhere, and that you have everything ELSE in perfect tune order.
Did in my case anyway.
Fix? None yet...
Old 08-26-2014   #14
Billy Mild
What are the PCV rubber pieces part numbers? Will Jerry's Gasket be the best place to get these kinds of pieces?
Old 08-26-2014   #15
PhillipsLT5
PhillipsLT5's Avatar
http://www.zr1specialist.com/HAT%20W...enum%20dvd.htm
Old 08-27-2014   #16
See if these are the PCV rubber parts you want to replace.
http://jerrysgaskets.com/store2/root...e91f10f4ed35c7
http://jerrysgaskets.com/store2/root...roducts_id=854
http://jerrysgaskets.com/store2/root...roducts_id=855
http://jerrysgaskets.com/store2/root...roducts_id=278
A26B is online now   Reply With Quote
Old 08-27-2014   #17
PhillipsLT5
Jerry is Da Man!
Old 08-28-2014   #18
Billy Mild
Looks like that last one is what I'm looking for. I think mine is leaking just a wee bit. Better replace that now rather than later.
Looks like the parts list is growing. Who know Corvette parts were as expensive or more than Porsche parts...
My wife is rolling her eyes now for encouraging me to pick up this beast. I have a torn apart motorcycle in my garage and now the ZR1 has taken over my "project focus".
Old 09-08-2014   #19
Billy Mild
What is the best place for vacuum lines and rubber fittings?
Do Vitton gaskets really make a big difference over Buna gaskets? Can o-rings be sourced at the local auto parts store or are they specific to the ZR1?
Old 09-08-2014   #20
Harvie
Buna and Viton are oring materials not gaskets. There are better than viton also, and real cheap. Just get the oring number and order them from Applied Industrial Tech. or take one in and they will match explain the diferences, and order for you.
Harvie is offline   Reply With Quote
