08-20-2014 | #11 |
Re: What did Sea Foam do for your motor?
Karl,
Ya oughta see what a quart of coolant at WOT will do in just 1/4 mile! The valves looked brand new!! But, I don't recommend it tho!
08-20-2014 | #12 |
Now THAT brings back memories of pouring ATF down the throat of my 72 Cutlass Supreme, opening up all four barrels and watching the neighborhood disappear in white smoke!
08-21-2014 | #13 |
Clears out skeeters too!
08-21-2014 | #14 |
I miss the sound of 4 barrel....
08-21-2014 | #15 |
08-21-2014 | #16 |
how do you properly apply sea foam on a zr1. do you have to wait till there is a 1/4 tank then pour can and run that tank down?? who could I do that safely on my zr1?
ed ramos #3028 |
08-22-2014 | #17 |
I poured Sea Foam down the crankcase vent tube on the pass. side of the air horn. Also poured the remainder in the tank.I just bought Sea Foam Spray that has a special applicator which fits into and under the air bridge so it can be sprayed with the motor running. Gonna try that tomorrow.
08-22-2014 | #18 |
Has anyone clamped the feed and return lines, mixed up some treatment, and added it through the a pressurized container into the fuel rails, then run the engine?
Getting the secondary injectors running might be an issue on an "intact" LT5. I do this to some of my CSFI(Central Port Fuel Injected) vehicles to keep the poppets from sticking. I am going to put some Seafoam in the 57 this Winter. This E10 fuel has me concerned. I do keep the tank full and it gets a good 1/2 hour run once a month.
peace Paul ZR-1 Net Registry Member #1494 |
08-22-2014 | #19 | |
08-22-2014 | #20 |
Read post #6 in this thread. I bought a spray can yesterday so I'll be trying that out today.
