Old 08-14-2014   #11
Made in USA
Default Re: Fuel Pressure Regulator keeps failing
When you put a fuel gauge on the rail does it hold pressure or bleed off? Ever test Fuel Pressure under load??
It holds pressure. I've not tested it under load other than at idle.
Made in USA is offline   Reply With Quote
Old 08-14-2014   #12
Made in USA
Originally Posted by ZZZZZR1 View Post
I'd wonder if it has anything to do with the fuel rail?
Is that connection not tight enough?
The fuel rails have been off several times. I don't think they are the issue.
Old 08-14-2014   #13
Schrade
Can you get a vid of the gas dripping out of the FPR vac port nipple?
Old 08-15-2014   #14
Made in USA
It's fixed now. I just want to keep it from happening again
Old 08-15-2014   #15
Schrade
Cool.
But exactly what was going on there? Where was the fuel coming from?
Knowing what might happen with others is good yUp!
Old 08-15-2014   #16
Made in USA
Cool.
The FPR is failing internally, allowing fuel to move from the supply side back into the plenum through the FPR's vacuum line.
