Old 08-03-2014   #11
Schrade
Default Re: Secondary Vacumm Pump question???
Some 2nd vac pump breakdown / diags snappics here, starting post #346 http://www.zr1.net/forum/showthread.php?t=21439&page=9
Old 08-03-2014   #12
Originally Posted by efnfast View Post
I'm no expert here, but I don't think the secondaries will open at all without the vacuum pump. And if it's revving to 7K, we can assume the secondaries aren't there?
You get vacuum from two sources for secondary operation (Vacuum pump and Plenum). There is a check valve that opens when plenum vacuum takes over. When the Vacuum pump is working that check valve is closed such that the Vacuum pump does not start evacuating the Plenum.
Secondary port vacuum diagnosis TIPS
Old 08-03-2014   #13
Roadster
Roadster's Avatar
Originally Posted by KILLSHOTS View Post
If you can redline the car with the pump disconnected, then your secondaries are removed. If they were intact, you'd have a hard time revving past 5000. Just turned off my key and confirmed that about an hour ago.
Hey, Chris, thanks for the confirmation on that.....
Still in the learning process with all of this, had no idea or reason to believe that the secondaries could or would be eliminated on my 94. And yes as stated before it does make sense that if the secondaries were in tact and the pump disconnected that the engine would not run as good as it does.
Now I need to find out who removed them and when.....hmmmmm!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-03-2014   #14
No.....you need to find out who clobbered up the Secondary removal and remove the plenum and do it right
Also.....you might have a modified chip to account for secondary removal......
It appears that you do not have functional secondaries....and possibly someone removed the secondary function without removing the whole secondary system (tying the secondaries open for example and leaving all the vacuum lines in place).
Old 08-03-2014   #15
Roadster
Roadster's Avatar
I kow that some day I will have to pull the plenum and yes, do it right....
If you might remember I had the Tim Holland Chip in there from the early GM engineering days of ownership. I then ordered a chip from Marc, and of course at the time had no idea that my secondaries might be eliminated. The main reason I went with the chip was to get the fans to come on & off at the lower temps. So Marc's chip that is in there now, does not have any provisions for secondary removal. And I know I keep repeating myself, but it runs great.....
I have noticed some oil around a Torx screw or two, especially around number 1 cylinder, so I need to snug those down.
Actually I need to retire to keep up with my vehicles, but I am a few years away from that. I'll just wait until the colder weather before I do a pull, did receive my DVD from Marc and with your links and people who have done it already, hopefully it won't be complicated once I get into it.
And being in the area of the WAZOO gang, maybe I can hook-up with them sometime in the future whenever they do a Plenum pull day.......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-03-2014   #16
Roadster
Roadster's Avatar
Thanks for the pic and link, some serious reading there for sure, it is bookmarked for future use......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-03-2014   #17
Roadster
Roadster's Avatar
Ok Chris, you got me in the mood, did my second complete WOT minutes ago (deserted road, no one around) out of 1st gear on a slight roll, looks like I shifted around 7200 r's just slightly above the 7k marking on the tach. Just unbelievable, I could do that all day long. Not a hiccup, just pure LT5 engine power....Coolant Temp @ 204* Oil Temp @ 208* fully warmed up motor....vacuum pump disconnected as usual, apparently no secondaries to be found......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-03-2014   #18
KILLSHOTS
There's the Permagrin!
Old 08-03-2014   #19
Roadster
Roadster's Avatar
You got that right......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-04-2014   #20
weldbead
what would be the down side of physically tying the butterlies open but leaving the the ailing vacuum system alone?
weldbead is offline   Reply With Quote
