08-03-2014 | #11 |
Re: HELP with electrical/fuse issue!
The under hood lamps are fed from inside the car through C100 that is a 3" X 3" 'pass-thru' connector that is down low and behind the battery vicinity. If you washed the entire under hood area and the left rear in the battery vicinity it certainly got drenched. It would take a very long time for it to dry out if indeed it got drenched. Remove the battery and you can access it I believe and maybe dry it out with a blow dryer. You should be able to follow the under hood harness back and along the left side to the C100 connector. You could have a break in the under hood harness between the C100 and the 2 connectors to the lamps. If the C100 got drenched it's got so much sealer that's likely dried out it's taken on a good bit of water.
Is that your problem? Very hard to tell but it could be the next most likely spot to concentrate on. If you have a FSM the C100 is displayed quite well in book 2 8A201-8. Good luck. |
08-03-2014 | #12 | |
08-03-2014 | #13 | |
Does it show 12V still? Not a real difficult task, and not intermittent. You got a connection right now, waitin' for you to see it, sort of, where there ain't supposed to be one.
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 08-03-2014 at 11:27 PM. |
08-22-2014 | #14 |
UPDATE: after several beered-up conversations with different buddies of mine, where we agreed that if the problem was anything other than a) water or b) corrosion left by water, it would be ONE HELL OF A COINCIDENCE, I finally gave up and took the car to an electrical specialist. $300 worth of troubleshooting later, he traced the problem to a pinched wire in the passenger door, and all is perfect now.
So, to review: when I started spraying water under the hood everything was perfect. When I finished, I had a blown circuit. Except, the two turned out to be somehow completely unrelated. That's what I call ONE HELL OF A COINCIDENCE!! My Corvette is undoubtedly, absolutely, unequivocally...a woman. I knew exactly what I did to piss it off but after I spent a bunch of money on it, it laughed at me and told me I'm completely wrong and an idiot. Thankfully, I'm also single!!! Last edited by KILLSHOTS; 08-22-2014 at 11:42 PM. |
