Old 10-24-2006   #11
tccrab
tccrab's Avatar
Default Re: Runs really bad at idle!
Originally Posted by ajaxajax2000
Sure enough. It was the MAP sensor hose. ECM code 33 and a loose sensor hose. Which is now in place again (a litle soft, needs to be replaced, I guess) and the car runs like a charm on idle.
A big thank's to all who helped out!
Peter
Great news!
Glad to be of help.
Get in it and DRIVE it!
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-24-2006   #12
Z Factor
Z Factor's Avatar
Thumbs up Re: Runs really bad at idle!
Peter
Isn't it great when you find a simple inexpensive fix to a frustrating problem?
Jeff's advice about not releasing the key to quickly when starting is absolutely correct and should prevent it from happening in the future.
Old 10-24-2006   #13
ajaxajax2000
ajaxajax2000's Avatar
Certainly is. And I learned a thing or two at the same time.
Thank's again!
Peter
'92 ZR-1, black on black, mostly stock (sold)
ajaxajax2000 is offline   Reply With Quote
