Old 07-16-2014   #11
gbrtng
gbrtng's Avatar
Default Re: Leaking Coolant Overflow Cap
Eric, it appears there is way too much coolant in the tank. My 91 shows "full" in the dipstick with about 1" of coolant. Somebody get him the correct cap ...
Old 07-16-2014   #12
PhillipsLT5
PhillipsLT5's Avatar
"bdw18_123" is referencing the coolant "surge tank" up above the evaporator/heater module at the windshield.
The level indicator of your cap is missing and I'd think that likely provided the "escape route" for your coolant! Look at the coolant cap I linked to in an earlier post. That is what should be there.
The link now only goes to CC home page so enter any of these part #'s in the search block: 10239665, 244412 OR 14069687.
My cap has the stick and then it has 3 less than 1/8" holes for venting. Mine would have been new from GM in '03 I believe. If you want a non-vented cap with a gasket the cap from my '03 SSEi is a fit with a gasket but it does say "DEXCOOL". I believe most any cap on the GM dealer shelf would likely be a fit from anywhere in the '90's to maybe later.
Correct
Old 07-17-2014   #13
bdw18_123
Oops, wrong coolant tank, lol! Forgot about that one...
But yeah, WVZR-1 is correct, there is supposed to be an indicator stick where that hole is in your cap, so that is undoubtedly where the coolant is leaking out from.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 07-17-2014   #14
Yep. The caps on our 90 and 91 look like this...
And, there appears to be some barrier material sandwiched under the 3-hole blister and the vent hole on the top of the cap.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-17-2014   #15
emmvette
emmvette's Avatar
Thanks guys, I ordered one from C. Central today. It helps knowing what it is supposed to look like!
[CENTER][SIZE=4][COLOR=red]1990 ZR-1 Red / Red[/COLOR][/SIZE][/CENTER]
emmvette is offline   Reply With Quote
Old 07-17-2014   #16
PhillipsLT5
Its a dipstick, cold & hot markings
Tags
overflow cap
