Old 07-03-2014   #11
Default Re: Learning to tune....
Originally Posted by mike100 View Post
Not sure if it is even possible with the GM ecm's, but I wish the TunerProRT hit-tracing feature was functional. I would love to see what areas on certain tables are being called on during any given load situation.
Mike,
Altho not real-time, VETuner will highlight those areas as it is recalcing the VE table. V2.0 will show what areas are being changed using color coding to show whether it's moving it richer, leaner, or no change in each cell and by how much. Up to now I do a compare of the previous bin w new bin in TPRT WHERE IT SHOWS +/- in each cell.
Old 07-03-2014   #12
Schrade
Mike,
Seems like we've gone right to advanced tuning here, from "Learning to tune"...
What does a wideband lm1 do? How does it work? Screenshots? Snappics?
Old 07-03-2014   #13
VETuner:
Old 07-03-2014   #14
I will get things back on track....once I get the datalogging equipment I will go over setup, software choice, etc. Move into data available, how tos...will do the same for the wideband.
Old 07-03-2014   #15
This isn't advanced tuning. It was an answer to mike100's question. And modifying the VE table is very basic stuff.
Old 07-05-2014   #16
Got the Xtreme ALDL and cables, first challenge....Tunepro RT says hardware not found.....I see Shrade had the same issue.
Old 07-05-2014   #17
You need to setup the COM port. Did windows detect the hardware correctly? Also do you have the correct ADX definition file?
Old 07-05-2014   #18
Its says its working properly(hardware) and I have the 8E adx file from Tunerpros website
Computer shows a properly working FT232R USB UART
Old 07-05-2014   #19
Not sure that ADX works.. I have a better one I know works
Old 07-05-2014   #20
No luck, I did find out that for just logging you hit the arrows....hardware only shows with an emulator....but still not working
