Old 07-01-2014   #11
Tony Davila
Tony Davila's Avatar
Default Re: New Catch Can upgrade
There is actually a spot on the inner fender to mount the cans with the existing screws and holes
Not if you have a Z with the ASR as mentioned but maybe if your creative.... I placed mine down there because
1
. Oil drains down hill.
2.
I didn't want to see them.
Tony Davila is offline   Reply With Quote
Old 07-01-2014   #12
Tony Davila
Originally Posted by Karl View Post
How & why are you using two catch cans?
Links below to my project write up on the subject.
http://www.zr1.net/forum/showthread.php?t=20318
http://www.zr1.net/forum/showthread.php?t=20320
Old 07-10-2014   #13
Karl
Karl's Avatar
See Details for Oil Catch Can Installation
Installation of Oil Catch Can shown on a 1991 ZR-1. I also have the same Oil Catch Can installed on 1990 ZR-1s
Some more Added Systems Here LT5 Added Systems
Does the air flow go from the back of the plenum to the front where the throttle body is or vice versa?
Old 07-10-2014   #14
Back to Front (from PCV valves to Plenum Vacuum) where the Throttle Body is.......
The Intake on the Oil Catch Can is on the top and the Exhaust is on the side.
This Purge Connection is on a 91' having the Charcoal Canister
on the passenger side behind the rear tire. The 90' Purge
Connection comes straight out and is connected to the Charcoal
Canister located under the drivers side Headlight.
Old 07-10-2014   #15
Tony Davila
Don't know who this photo belongs to but this is another great spot to install a catch can.
Old 07-13-2014   #16
5ABI VT
I want a catch can now. How much oil are you guys getting over any amount of time ? I think my dipstick isn't sitting properly on the tube because it feels loose and I'm wondering if it may be affecting the System.
Old 07-13-2014   #17
Karl
Karl's Avatar
I have had my catch can installed with under 1000 miles on it and have accumulated about half a cup of oil.
These are mainly daily driving miles, with the occasional wot run here and there.
Old 07-13-2014   #18
5ABI VT
Wow that's quite a bit! Any reccomendations on a can ? Would like a black one if possible to keep it hidden.
Old 07-13-2014   #19
Karl
Karl's Avatar
http://m.ebay.com/itm/180880329871?nav=SEARCH
I think you can get it in black. The oil is now visible so its adding up!
You can look on Ebay for more options.
Old 07-13-2014   #20
secondchance
That's my setup.
