Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 06-27-2014   #11
Default Re: Dyno'd today, thanks Locobob.
Originally Posted by efnfast View Post
Hard to say on SOTP, it was almost 6 months in between drives with the new top end parts. Also should add, Marc chip done with exhaust, and redone for the porting. Marc may have gotten a little aggresive, we think we saw some detonation at between 6k and 6500. -Steve
I'd be surprised about that. Did you run a WB O2 with the runs? Detonation usually happens somewhere right around torque peak. Likely why u see a bit of a sag in the torque curve at the rpm before it continues further up.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-27-2014   #12
efnfast
We had some fluttering in the curve at top end. He suspected detonation. A/F was about 12.5 when it happened. Didn't feel it, just see it on the curve.
efnfast is online now   Reply With Quote
Old 06-27-2014   #13
You will usually see "fluttering" especially at top end. There's fluctuations that could have something to do w traction on the roller etc. There's also "smoothing" which is part of the software. I've bumped my timing up to 34d+ at top end and motor did not detonate, it just dropped in power. I'm pretty sure Marc's cal is more conservative than that. 12.5 is a bit fat IMO, but that will also be dependent on whether the overall tune is rich or lean. I'd also want to see what plugs look like.
Old 06-27-2014   #14
efnfast
Thanks Dom, eases my mind to think I'm not detonating at 6 grand.
Old 06-27-2014   #15
1990 quasar blue
OBX ceramic coated headers and OBX exhaust.
SAE adjusted, but it was a perfect day and there was no correction. -Steve
Thanks. If you want to meet up in epping one day let me know.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 06-27-2014   #16
Steve,
Obviously you pull a few plugs and just make sure there's no aluminum pitting in the ceramic.
Old 06-27-2014   #17
efnfast
Where in MA are you?
Old 06-27-2014   #18
efnfast
Dom, the plugs look to have sort of a grey color to them. The two I pulled have gone from the .0050 (at Marc's recomendation) to .0060. Iridium plugs.
Old 06-27-2014   #19
1990 quasar blue
South coast. About 1/2 hour from the cape.
1990 ZR1 #2574
1 of 19
Old 06-27-2014   #20
efnfast
Headed to Worcester next weekend.
Epping to watch the races, or Epping to race? -Steve
