Old 06-22-2014   #11
WVZR-1
Default Re: 3rd brake light has no power at the bulbs ... brake light switch? ---
Originally Posted by alwayscode390 View Post
LH = drivers side, right?
I'll find time in the next couple days to do some searching and testing as long as the rain stops, and I will update with what I find out ---
Everything I do I do sitting behind the steering wheel
LH = DRIVER
except when doing a transverse engine and then I stand behind the flywheel looking towards the water pump (EX: exhaust manifold closest to front bumper is NOT front but LH)
Old 06-22-2014   #12
Schrade
Switch...
Old 06-22-2014   #13
WVZR-1
14043256 is the cruise release switch - not what the OP needs. There will be no "plug and pray". This will likely be the needed fix and the diagnostics should eliminate "the pray"!
Old 06-23-2014   #14
Rumbln70SS
Rumbln70SS's Avatar
I just went through the exact same problem, for the same reason.......two switches, one for the cruise and one for both sets of brake lights. Mine was the switch, $8.00 at Advanced Auto.
Hope this helps.
Tony
1970 SS Chevelle 396 with a 580 BBC
1974 Corvette Roadster
1990 Corvette ZR-1 Modified #952
1993 Firehawk (His)
2002 Firehawk (Hers)
2008 BMW 335xi DD
1988 S10 Drag Truck - Best ET 10.13@131
Rumbln70SS is offline   Reply With Quote
Old 07-03-2014   #15
alwayscode390
I took off the old brake switch, and it showed continuity ... but replaced it anyway with an ACDelco piece.
My 3rd brake light is now working again to my surprise!
Thank you all for your help ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
90' ZR-1 Corvette LPE #699
alwayscode390 is offline   Reply With Quote
Old 07-06-2014   #16
Rumbln70SS
Rumbln70SS's Avatar
Glad to hear!!
Tony
1993 Firehawk (His)
2008 BMW 335xi DD
Old 07-12-2014   #17
c4koh
c4koh's Avatar
Good to see this resolved!
I had the "reverse" situation - my third brake light would light, but the 4 brake lights (though left/right, and driving lights (lower power 'ON' all worked).
Problem turned not to be the brake switch, but a small 37uF capacitor across the connection (blue and orange wires, I think I remember it as, but don't rely on that from my memory!). I replaced the capacitor and they all worked again. Either a lose or shorted connection.
This was on a 92, I seem to remember at the time that this was put on in 92 (so may not be there on the 90) to cope with arcing potentially messing up the ABS and ASR...
Anyway, just my 2c, but if a new brake switch fixed it - good and glad to hear it
c4koh is offline   Reply With Quote
Old 07-25-2017   #18
1LEZ
This thread just gave me the information to fix my third brake light problem. Switch! Thanks!!
1LEZ is offline   Reply With Quote
Old 07-25-2017   #19
1LEZ
Hope this helps.
Thanks!! Great info. Used the part number you gave too
Old 07-25-2017   #20
Young1
Young1's Avatar
The brake light switch change out is a memorable experience of muscle cramping!
