#11 |
![]() Join Date: Apr 2013
Here's a link to a DIY I did on mine..
http://www.zr1.net/forum/showthread.php?t=20819
#12 |
Good evening to all, for the clutch master cylinder, brake oil dot 4 is compatible?
thanks |
#13 | ||
![]() Are these trannies smooth when they are right? How do they compare to a T56? Good call on the fill plug......that would suck lol. Quote:
Tony 1970 SS Chevelle 396 with a 580 BBC 1974 Corvette Roadster 1990 Corvette ZR-1 Modified #952 1993 Firehawk (His) 2002 Firehawk (Hers) 2008 BMW 335xi DD 1988 S10 Drag Truck - Best ET 10.13@131 |
#14 |
Update:
Talked to Jim today from Power Torque Systems. Seems like a real nice guy and very knowledgeable. He mentioned that I have to have original parts in order to rebuild them so I started tearing into the car this evening. Low and behold I have original parts! I was able to get the master off, but I am having a little trouble with the slave. Anyone have any tips/tricks to getting it out? Mounting bolts are out, but I can't seem to get to the steel line and remove the unit. One other question, my third brake light is not working. When I got under the dash, I noticed there isn't a connector plugged in. What color are the wires that connect to it? I found a few things unplugged and I need to figure that out before inspection again. Looks like someone removed the whole ABS system at one time.
#15 |
Not sure exactly which wires go to what - but there are 2 brake light switches. My 3rd light wasn't working and one of the two switches was bad... Wish I could help more but the dealer fixed this one while I had it there for inspection...
#16 |
![]() Join Date: Apr 2004
One of the brake switches is for the CC.
#17 |
![]() Join Date: Jan 2010
#18 |
LoL and mine is disconnected
![]() Got everything off tonight......shipped to Jim tomorrow for the rebuild....does anyone sell the replacement hard line? Mine is tweaked just a bit. ![]()
Tony 1970 SS Chevelle 396 with a 580 BBC 1974 Corvette Roadster 1990 Corvette ZR-1 Modified #952 1993 Firehawk (His) 2002 Firehawk (Hers) 2008 BMW 335xi DD 1988 S10 Drag Truck - Best ET 10.13@131 Last edited by Rumbln70SS; 06-11-2014 at 11:08 PM. |
#19 |
Hey thanks anyways! People on this forum are great!
#20 |
![]() Join Date: Oct 2013
Not sure about the wires or the 3rd brake light and how it's tied to the abs stuff.
As far as the getting to the line going into the slave cylinder, it's a braided steel flexible line....like the braided lines a lot of guys use for brake lines. You should be able to pull the slave out (with some wiggling), drop it a little, and get a line wrench on the line. Worst case, and I haven't had to do this on any of the ones I've done (2 LT4s and a ZR-1), you can unbolt the little bracket that holds the line to the frame or firewall to give more play....just follow the line down from the topside and you should be able to get to the retainer. Like I said, I've never had to do that, though. I've always found the master to be a whole lot harder to get out. It was easy on the LT4 cars compared to the Z....a whole lot less wiring and stuff in that area. When you put it back together, you can put the line on, tighten it up, then wiggle it back in there, feed the two bolts in and tighten them down. Jim's a great guy and will answer your questions extremely specifically if you ask him. I don't get anything out of referring people to him, except that it keeps him in business so that I can go to him later too! Chris |
