Old 05-12-2014   #11
Karl
Karl's Avatar
Default Re: testing the ALCL. poor cold start running
Originally Posted by Franke View Post
What XfireZ51 said plus I am surprised that it runs with that low of a fuel pressure. Interesting.
What's really interesting is when I modified my old 85 with a new engine and such, first thing to go was the fuel pump.
Guess it's coincidence....
Old 05-14-2014   #12
Karl
Karl's Avatar
I just finished changing the fuel filter and the car now holds 22psi at idle.
Time to pull the fuel pumps.....
Old 05-14-2014   #13
Karl,
Check to see if you have the plastic clamps on the pumps. If so, I would replace w metal hose clamps and see what happens then before replacing pumps. Altho there's always the "while you're there" rule and the corollary which is "may as well".
Old 05-17-2014   #14
Karl
Karl's Avatar
Fuel pump assembly has been removed. All looks good. Before I replace the fuel pumps with ones from a suburban 454, is there a test I can do to confirm they are bad?
Old 05-17-2014   #15
Karl,
I would replace those black plastic clamps first then put pumps back in the tank. See what ur FP is. Its easy enough to pull the pumps again if u need to replace them.
Fuel pump assembly has been removed. All looks good. Before I replace the fuel pumps with ones grok a suburban 454, is there a test I can do to confirm they are bad?
Old 05-17-2014   #16
Karl
Karl's Avatar
Are you referring to the black clamps around the hoses?
Old 05-18-2014   #17
Yep, replace them w hose clamps. They get loose and fuel will squirt out lowering the FP.
Old 05-18-2014   #18
Karl
Karl's Avatar
One last question. How tight should the clamps be?
Old 05-18-2014   #19
Karl
Karl's Avatar
The ones I replace them with? Hand tight?
Old 05-18-2014   #20
Just don't have the rubber squeeze through like dough.
