05-08-2014 | #11 |
Re: CORVETTE C4 AIR CLEANER
zr-1,
Take a look at this. http://www.zr1specialist.com/HAT%20W...ucts/hoops.htm I thought having you describe it in Italian would make it easier for you. I was able to understand it because your explanation was more precise in Italian. No apologies necessary especially since we are an international group.
05-09-2014 | #12 |
no, not in the fitting bellows.
but inside the entrance of the air cleaner, to avoid crush, when you pull the metal collar |
05-10-2014 | #13 |
I would suggest putting the hoop inside the air cleaner opening instead then. I'm also wondering how much you are tightening the "hose clamps". If you are tightening the clamp to keep the bellows "sliding" off the air cleaner housing, its probably because the bellows are collapsing. If you reinforce the bellows w hoops or sheet metal cone etc, you'll see it does not move because the bellows is not being pulled away. Capito?
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 05-10-2014 at 03:52 PM. |
05-10-2014 | #14 |
If I am reading this correctly...Where the bellows hook to the plastic air cleaner assembly it is all plastic no metal reinforcement, If you are crushing the plastic opening you are over-tightening the bellows screw band.
05-11-2014 | #15 |
in the product standard, inside there is no frame?
or mistake. or I'm wrong |
05-11-2014 | #16 |
Just hard plastic.
05-12-2014 | #17 |
Yes no metal inside if it from the factory it's just plastic.
