05-01-2014 | #11 | ||
Re: Couldm't get the 94 in gear......
My only point was that "not set up to bleed" wasn't the whole picture, and I expanded on that from my conversation with Jim. The extra red emphasis that wasn't originally there, without an explanatory link, just didn't come across well.
Mark '90 ZR-1 #1322 Daily Driver, 64k and counting Black/Gray [IMG]http://i208.photobucket.com/albums/bb49/mlitherland/IMG_0326_zps3d50d8cb.jpg[/IMG] |
05-01-2014 | #12 | |
Change the fluids (clutch / brakes / transmission) and see how things go. That might fix the issue. David |
05-01-2014 | #13 | |
I couldn't agree more about Jim Jandik , he is the man!!! Great products / service and discussions with him. Thanks for editing your post and giving feedback on your brake upgrade experience. :cheers David Last edited by ZZZZZR1; 05-20-2014 at 07:46 PM. Reason: edited comments per Cliff's request |
05-01-2014 | #14 |
4cam.....I was only mentioning the fact I went through the same thing on my 90' and thought you prolly did not see it so highlighted it in BOLD RED. It is an important issue as you verified that the Stock Clutch Slave Cylinder in a 90' (maybe 91') does not have the bleed valve any longer. And as I found out it is a mess to try to bleed the Slave Cylinder by breaking the lines. You did a nice right up on the background confirming what we both experienced and mentioning the self bleeding characteristic. Thanks
Oh....will mention again...(this the third time)....I got a New Clutch Master and New Clutch Slave from Jerry which I installed both in around 30 minutes including bleeding (New Clutch Slave has a nice bleed valve). My wife Priscilla pumped the Clutch when I opened the bleed valve each stroke. Clutch releases perfectly now. New Clutch Slave DOES fit around a Stock Exhaust pipe without disconnecting the pipe just in case anyone is wondering.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-02-2014 at 12:53 AM. |
05-01-2014 | #15 |
How did you bleed it,
the bleed port is on the bottom of the new AC Delco slaves? What genius designed that? Back filled mine thru the bleed port (bottom to top). |
05-01-2014 | #16 | |
Back filling would definitely work better but gets messy with connections/hose that I did not have handy. Maybe that is why the bleed valve is on the bottom of the Slave Cylinder I did use a few sheets of paper towel under the bleed valve. Yes...I bled it before installing it on the bell housing. Also tried to tip it up in rear as I bled it to get air out and also when you do that the steel line tips down which makes it more difficult. I recall I also pushed the plunger against bell housing to destroke the Slave Cylinder with bleed valve open. I just tipped rear up and twisted it so bleeder was not all the way on bottom and said to wife "PUSH and HOLD". I then cracked the bleed valve and closed bleed valve. Did that a few times keeping fluid in clutch reservoir. Then it is tight but you can depress the plunger a bit for positioning Clutch Slave on Bell Housing. Make sure you get some lube on plunger end for Clutch Fork...also making sure you have the plunger inserted properly on Clutch Fork. After Priscilla got good full stroke clutch pedal pressure I called it a day and as 4cam suggests I think it will self bleed any remaining air over a period of time.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-01-2014 at 10:23 PM. |
05-01-2014 | #17 |
You're right, it was a little messy!
But it seems to have worked OK, got a good pedal now. |
05-01-2014 | #18 |
Dave how many miles do you reconmend having the fluid changed?
I have 31 k in my car and might change it before going on the mountain run. Nelson007 |
05-02-2014 | #19 | |
Many say clutch fluid / brake fluid should be changed every 2 years, but I would yield to Marc Haibecks advice. If you don't know when your fluid was changed, that's not a bad idea. Look forward to seeing you in BG!!! David |
05-02-2014 | #20 | |
A quick change is a 10 minute job and you'll get 90% of the fluid flushed, and you don't have to go under the car. Just suck the old fluid from the reservoir with a turkey baster and wipe the stuff out until it's clean. Put in clean DOT4 to the fill line and give it 20-30 pumps - you'll see the air bubbles coming up through the reservoir. Suck the fluid out, refill and repeat. Do this about 4 times and you'll run about a half-bottle through, most of the fluid will be changed. Now if the clutch goes soft again, the slave is the culprit 95% of the time. A true 100% bleed will require diving under the car and using the bleeder valve, and isn't possible on a 90 with the original slave.
