#11 | |
![]() Join Date: May 2005
#12 |
![]() Join Date: Nov 2007
#13 | |
![]() Join Date: Jan 2009
Can't wait for the defender of acronyms to pop his head up. That would be the DA squad. (pronounced duh) Coincidentally it was when the "FSM" acronym showed up that I cracked and first mentioned the acronymism illness. (that would be AI) ![]() Reminds me of the tale of the Tower of Babble
#14 |
One of the worst abusers of acronyms, aside from car enthusiasts (IMO
![]() BUT, all kidding aside, LantanaTX makes a very good point. As a matter of fact, we all could benefit from a STICKY NOTE that contained a list of the more common items, yes??? OK, Scott, I'll be the first to defend them: I ain't skeert o' you! ![]() Properly used, acronyms reduces the tedium of writing and reading where a term is used multiple times in a text (emphasis on "properly used") BUT!, for what is is worth (FWIW), good etiquette is to first introduce an acronym to be used by first writing the term out, followed by the acronym in parentheses ( ), unless the intended audience is completely familiar with the term and it's acronym. Examples: Factory Service Manual (FSM) or Secondary Port Throttles (SPT), Injector Housing (IH), etc. That way the writing can be sped up w/o confusing the intended audience and thus disrupting the flow of thought the writer wishes to convey to the reader. (Thus endith the tech writing etiquette lesson ![]() Just a thought ![]() Last edited by Paul Workman; 04-29-2014 at 07:10 AM. |
#15 |
Thanks to Dynamic EFI for this list.
Acronyms and Abbreviations ~T - Inverse Temperature ~AFR - Inverse Air Fuel Ratio #/Hr - Pounds per Hour ABS - Anti-lock Braking System A/C - Air Conditioning ADC - Analog to Digital Converter AE - Acceleration Enrichment AFPR - Adjustable Fuel Pressure Regulator AFR - Air Fuel Ratio AIR - Air Injection Reactor ATDC - After Top Dead Center ALDL - Assembly Line Diagnostic Link BARO - Barometric Pressure BBC - Big Block Chevy BBL - Barrel BCM - Body Control Module BDC - Bottom Dead Center BIN - Binary BLM - Block Learn Multiplier (long term fuel trim) BSFC - Brake Specific Fuel Consumption BPC - Base Pulse Constant BPW - Base Pulse Width BTDC - Before Top Dead Center CAFE - Corporate Average Fuel Economy CARB - California Air Resources Board C - Celsius CAT - Catalytic Converter CAT-CON - Catalytic Converter CCI - Computer Controlled Ignition CCP - Charcoal Cannister Purge CDI - Capacitive Discharge Ignition CEL - Check Engine Light CFI - Cross-Fire Injection CLT - Closed Loop Term (fueling correction) CNP - Coil Near Plug CTS - Coolant Temperature Sensor dTPS - Delta Throttle Position Sensor dMAP - Delta Manifold Absolute Pressure Sensor DC - Duty Cycle DE - Deceleration Enleanment (opposite of AE) DFCO - Decel Fuel Cut Off DIS - Distributorless Ignition System DRP - Distributor Reference Pulse EBL - EmBedded Lockers system ECM - Engine Control Module ECT - Engine Coolant Temperature EGR - Exhaust Gas Recirculation EGT - Exhaust Gas Temperature EPROM - Eraseable Programmable Read-only Memory ESC - Electronic Spark Control, knock detection & retard EST - Electronic Spark Timing, SA control F - Fahrenheit FAR - Fuel Air Ratio FPR - Fuel Pressure Regulator Ft/Lb - Foot Pounds (torque) GPS - Grams Per Second Gms/Sec - Grams per Second HEI - High Energy Ignition HP - Horse Power HYST - Hysteresis IAC - Idle Air Control (an actuator) IAT - Intake Air Temperature (sensor) INT - Integrator (short term fuel trim) Km - KiloMeters Km/L - Kilometers per Litre KPa - KiloPascals KPH - Kilometers Per Hour LDA - Lobe Displacement Angle (camshaft, same as LSA) LM - Launch Mode LSA - Lobe Separation Angle (camshaft, same as LDA) LV8 - Load Variable, 8-bit LV16 - Load Variable, 16-bit MAF - Mass Air Flow MAP - Manifold Absolute Pressure MAT - Manifold Air Temperature (sensor) MPG - Miles Per Gallon MPH - Miles Per Hour MPFI - Multi Port Fuel Injection mSec - milli-Seconds (.001 second) NB - Narrow Band O2 sensor N-Alpha - RPM & Throttle position for load N/V - Ratio of Engine speed (N) to Vehicle Speed (V) O2 - Oxygen Sensor value P/S - Power Steering PA3 - Knock Counts (PA3 is the name of the ECM counter) PCM - Powertrain Control Module PCV - Positive Crankcase Ventilation PE - Power Enrichment (see WOT) PPH - Pounds Per Hour PROM - Programmable Read-only Memory PSI - Pounds per Square Inch PW - Pulse Width PWM - Pulse Width Modulation RPM - Revolutions Per Minute SA - Spark Advance SBC - Small Block Chevy SD - Speed Density SES - Service Engine Soon TACH - Tachometer TBI - Throttle Body Injection TCC - Torque Converter Clutch TCM - Transmission Control Module TDC - Top Dead Center TF - Throttle Follower (IAC function) TPS - Throttle Position Sensor TSA - total spark advance uSec - micro-Seconds (.000001 seconds) UEGO - Universal Exhaust Gas Oxygen sensor (a WB unit) VAC - Vacuum VAFPR - Vacuum Adjusted Fuel Pressure Regulator VATS - Vehicle Anti-theft System VE - Volumetric Efficiency VRFPR - Vacuum Referenced Fuel Pressure Regulator VSS - Vehicle Speed Sensor WB - Wide Band O2 sensor WOT - Wide Open Throttle (see PE) WYSIWYG - What You See Is What You Get |
#16 |
Great list. It should be copied into a sticky. I would have been very helpful when I joined the site and am sure it would help others. The etiquette examples would have been great to. I have been active on the Mini Cooper, Mercedes, BMW, Lotus, Off road racing, and Crossfire sites and never had a problem with acronyms.
#17 |
![]() Join Date: Dec 2003
Like with everything, moderation is the key to well being. A few, very well known is good. Taken to excess is not good. If I have to stop reading and hunt up a translation key to understand it, I'm not going to read it. NWMT.
#18 |
Dang you're good!!!
#19 | |
AU D LOX ![]() |
#20 |
Use of acronyms in moderation would be good.
The idea of showing how knowledgeable one is by introducing new acronyms that are certainly not understood is arrogantly, and blatantly rude. Also not introducing or using new acronyms out of the blue would be great. I would think until it's added to the sticky list of terms it (as has been mentioned) should be constantly defined while used e.g. FT(Flat Tire). Above all beating up on newbies for complaining about unfamiliar acronyms should not happen and in fact should be banned as unhelpful. Creating a new list to be held up at the gold standard sticky is fine too. I would hope it to be minimalistic though. Putting every acronym under the sun in there seems ludicrous. Only terms used OFTEN on this forum should qualify. AND there should be a space between alphabetically separate groups for ease of use. IMHO ![]() Finally, there's no stopping the laziness of using acronyms but basic clarity of communication suggests not only minimizing it but discouraging it. At minimum a thread should, at first opportunity, define the acronym in a low numbered or fist post then use it openly. As was said, having to refer to a dictionary of terms before being able to get through a post is just wrong. This thread topic is "Give us newby's a break". Well, lets do just that. (WLDJT)
