Old 05-19-2014   #11
Fully Vetted
Fully Vetted's Avatar
Default Re: You know what really sucks...
Glad to hear you made it home, Joe. No other reoccurance of the fuel problem on the way home?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 05-19-2014   #12
JThomas
JThomas's Avatar
I got to Dayton, Ohio and was getting off the freeway. The car sputtered and I limped it into the gas station. I put ten gallons of fuel in the car and fired it back up. No other issues the rest of the way home, however I did stop every 100 miles and topped it off again. Strangest thing, but we'll get it worked out.
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 05-19-2014   #13
Joe,
Just an FYI, but I ran out of fuel on the way down and got some gas in lower part of Indiana. Car ran a bit rough. Then I pumped some Shell near the I-65 interchange for the hotel. Car ran great and nearly 25mpg at 75+on the way home. Pulled the plugs and you could see they're using some different additives.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-19-2014   #14
JThomas
JThomas's Avatar
Thanks for the insight Dom.
Joe Thomas
Old 05-19-2014   #15
I think I need to check out my pumps, I have a feeling I am on borrowed time with them with all the replacements i have seen/heard about
Old 05-20-2014   #16
Toyvet1
Sounds like a torn rubber hose between pump and sending unit ?
Toyvet1 is offline   Reply With Quote
