Old 04-09-2014   #11
Mystic ZR-1
Mystic ZR-1's Avatar
Default Re: Transmision Problems
Originally Posted by ZZZZZR1 View Post
Well said Scott.
Definetly change the transmission fluid before you do anything drastic...
I think the BMW castroil is the best?
What grade?
And believe it or not, I've found the local BMW stealership is the least expensive place to get the oil!
Old 04-09-2014   #12
Racinfan83
Yep. That's where I got mine. Cheaper then I could get it online even...
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
Old 04-11-2014   #13
Bob Eyres
It might be helpful to service the hydraulic clutch first. Replace the fluid in the reservoir, and bleed the clutch so that you have full release when shifting.
If the clutch isn't working fully, it could be the cause of your trans problems.
Old 04-11-2014   #14
scottfab
scottfab's Avatar
very good point !
Scott
Old 04-11-2014   #15
MRC1994
Thanks for the info guys. I've got the tools and know which end of the screwdriver to hold and have worked on clutches and transmissions before, any tricks I should know about when pulling this transmission?
Greg
1994 ZR-1 #325
MRC1994 is offline   Reply With Quote
Old 04-11-2014   #16
scottfab
scottfab's Avatar
Greg
The ZF6 weighs 149lb so use two long bolts with the heads cut off
to slide the thing out onto a jack to avoid damaging things. I use 8in long bolts.
Helps too when aligning it up to reinstall.
Best practice is to also replace the pilot bearing while in there depending on if you know it was done since new.
Scott
Old 04-11-2014   #17
Mr Blue
Good advice, I have made that mistake before. I would also look at the throwout bearing, even though it is expensive. Double wook is not fun.
Regards
Mr Blue is offline   Reply With Quote
