#11 |
![]() Join Date: Feb 2011
There used to be a product that came out in the 90's. Like BG44, but you pulled the fuse on the fuel pump and ran a can of detergent solvent/fuel on the fuel rail for a few minutes.
Nothing new here. Where this discussion should end up is how do you clean valve tops in a direct injected engine. No fuel or detergent outside of the combustion chamber- probably be some kind of water injection treatment that isn't too detrimental to catalysts or something. Audi's have had this problem for some time on their DI 2.0 liters. |
#12 |
![]() Join Date: Jan 2009
this is the correct way to de carbonize
#13 |
![]() Join Date: Oct 2013
I saw them do something similar...although I'm at work and can't look at the video... on Wheeler Dealers. They had a car having a tough time passing emissions and hooked up some kind of machine to the fuel rail to provide ionized fuel with the fuel pump disconnected. If I recall, there were several cycles run through it and there were pretty dramatic drops in the emissions numbers.
Not sure if I'd want to run that thing on an LT5, give the expense if it damaged it, so I'll add one more vote for the Italian tune up method of giving it a good WOT run here and there. |
#14 | |
![]() Join Date: Jul 2005
Pedal to the metal boys!! Given the way most of us drive, and using premium gas, carbon buildup should not be a problem. Last edited by John Boothby; 04-03-2014 at 02:01 PM. |
#15 |
[QUOTE=csavaglio;199526]I saw them do something similar...although I'm at work and can't look at the video... on Wheeler Dealers. They had a car having a tough time passing emissions and hooked up some kind of machine to the fuel rail to provide ionized fuel with the fuel pump disconnected. If I recall, there were several cycles run through it and there were pretty dramatic drops in the emissions numbers.
That is where the vid came from. Big Ed from Wheeler Dealers. |
#16 |
#17 | |
like was said above- ATF and/or water has worked for years- just don't do the ATF thing on a car with catalytic converters that still work. |
#18 | |
![]() Join Date: Jul 2010
The Top Engine CLeaner has changed formulations as per US EPA, Canada formulation is different. |
#19 | |
