04-01-2014 | #11 |
Re: Exhaust Install Question
Is the center muffler supposed to be touching the diff?
2003 Z06 Electron Blue/Black 1990 ZR-1 Black/Black #1446 (Sold) |
04-01-2014 | #12 |
This is a common problem. For me it has always been the driver side pipe hitting. Marc H says just get a breaker bar or a large strong screwdriver and place it between the pipe and the diff and lever it down. He said it takes a lot of force but will get the pipe to bend. I did this but also took a small square of silicone hose material (about 2" x 2") and put it between the pipe and the diff, held in place with some hose clamps. Seems to work fine. Did it on both my old Corsa and on the stock system with cutouts. --Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 04-01-2014 at 05:44 PM. |
04-01-2014 | #13 |
What Warp Ten said. I had the same issue and just adjusted it with a large tool too. Looks good. How did the old flange come off?
04-01-2014 | #14 |
Yep, driver side. I got the flange off with the cut off saw. I'll post pics later.
04-02-2014 | #15 |
The exhaust is louder than I thought it would be at idle, which is great. But it isn't as loud as I thought it would be at WOT. Maybe it's because i'm in the car and not behind it to hear just how loud it is. Overall i'm very happy and it's leaps and bounds better than stock and well worth the money. I would say that when I buy a C5 Z06 some day i'll probably go with the Corsa Xtremes, but i'll see how I feel after living with the Sports for some time.
04-02-2014 | #16 |
There is no need to bend anything at all.
Just loosen up all the fasteners, place a 2x4 between the diff and the pipes then tighten back up. Lastly when you're fine on the pipe to diff clearance, set the muffles straight and tighten fasteners then set the tail pipes where you want them.
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 04-02-2014 at 06:01 PM. |
04-02-2014 | #17 | |
Absorbing vibration - acoustic, mechanical, etc., goes a LONG way. Even if only in the exhaust lines. Take a ride on Germans' HSR train. Those rubber-inset wheels make you think you're puttin' along @ 70, when the whole train is zippin' along @ 190 !!! Go rubber, or vulcanized Silicone bushing.
04-08-2014 | #18 |
04-08-2014 | #19 |
I like it.
04-08-2014 | #20 |
I like it.....sounds like a mean 4cam motor.
If I want old school muscle, I would climb in the 65 L78 or the 69 Z28 and row through the gears. |
