03-20-2014 | #11 |
Re: Oil catch can
Well Chuck it might catch something . Maybe looks good at shows as a curiosity item too. I mounted mine next to the brake booster/master cylinder and made a bracket to mount it to the MC bolts. I ran the hoses to the firewall and up to the PCV and over across the top of the cam cover to a pipe I made to pickup the vacuum port. Looks good to me. One thing I did do was test the can for vacuum leaks before I mounted it and it was a good thing I did as the clear hose sight glass fittings were junk. I replaced them with all brass and new tubing and it was good to go.
03-21-2014 | #12 |
Re: Oil catch can
Yeah - definitely looks good there Franke...
And I'm goin' crazy thinkin' of the dynamics of a catch can. If the oil is in [almost] vapor phase, as close to vapor phase as it can actually be, how is it 'catching', to fluid phase, in a can? By reduction in velocity, of gases in the can / cylinder??? And if THAT's it, then how much can accumulate before volume in the can is reduced by accumulated oil??? If that's NOT it, then a membrane of some sort can catch it, and it will run down to the bottom of the container. Until it fills. The can CANNOT be a maintenance-free object. It has to be emptied... I saw how much oil accumulated in the plenum inlet, when I pulled the TB after only half a dozen Closed Loop cycles, after the top end finish earlier this year. Jerry said the amount of oil is negligible, with respect to a fouled burn. Fine. With that oil removed from the burn, it has to be marginally better. IF IT'S REMOVED....................................
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 03-21-2014 at 05:47 PM. |
03-21-2014 | #13 |
Re: Oil catch can
Haven't we discussed this once before? For some reason this feels like deja vu all over again. The oil is coming out of suspension traveling through the filtration in the catch can. It accumulates on the fibers and drops to the bottom.
03-21-2014 | #14 | |
Re: Oil catch can
Jerry is right about the oil amount being negligible with respect to a fouled burn. This of course is dependent on the engine characteristics too. I would expect any extended high RPM drives from this engine to produce much more vapor than driving around the neighborhood. The fact remains that it does produce oil in the intake and has been discovered in the MAP hose as well as other places in the engine, so I am experimenting to see if that will be cured and am curious if it will change the emissions gases as well. |
03-21-2014 | #15 | |||
Re: Oil catch can
If you don't want ACCUMULATED oil discussed ANY FURTHER, fine - you're the boss. If you DON'T object, I'd like to hear 1) What everyone does, if anything, about the oil that catches in the can. And 2) If no one does anything about it, why not? Why then do you HAVE the can???? I think it's a legitimate discussion.................
03-21-2014 | #16 |
Re: Oil catch can
Well....lets see....I checked my oil catch can on a 90' and 91' and after say 300 miles had about 10 TBS of oil.....maybe more or less
I discarded that oil I like the looks of the Oil Catch Can See Details for Oil Catch Can Installation Just for you Schrade .....I installed A new Master Clutch Cylinder and New Clutch Slave Cylinder today on my 90' (Both from Jerry) and I have no clue what the issues are regarding Clutch master and Clutch Slave Cylinders any more as these from Jerry function perfectly and are easy to install (both Master and Slave) on a Stock 90' with Stock Exhaust And as always.....from time of order had in hand two/three days and super packaging
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-21-2014 at 09:33 PM. |
03-21-2014 | #17 | |
Re: Oil catch can
http://youtu.be/4e9CkhBb18E
03-21-2014 | #18 |
Re: Oil catch can
Well, you're the MAN there, Cliff...
But about the 10 TBS; was the can full? If it was, how long had it been full, suckin' in the overflow? Like I said before, I had brand new oil pooled @ the inlet, after 5 - 6 Closed Loops, idling in the carport, post top end work, with 32k on the mill. And like Jerry said, there's room for improvement. So here's what we're thinkin' - plastic see-through catch can, with a drain line to the Air Filter housing up front. Drain line with a check valve, or inverted PCV, integrated into the can. Motor off, or hammer down, oil drains. Low rpm's, vacuum keeps PCV integrity, and collects oil. Unless anyone has fabbed up something, or even an idea, and they got their keyboard lockjaw-ed cat got their tongue???????
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 03-21-2014 at 10:27 PM. |
03-21-2014 | #19 | |
Re: Oil catch can
03-21-2014 | #20 |
Re: Oil catch can
This is the one I use and I really don't have a lot of oil in it or in the plenum.
Had more in plenum before using this. http://www.ebay.com/itm/CORVETTE-C5-...eb373f&vxp=mtr
