Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Audio/Electronics
Old 03-17-2014   #11
Default Re: New Sound System
Originally Posted by White Bullet View Post
It was not bad. The only cutting was the back support for the factory radio. Once it was out the radio fit just fine. I used a American International GMK311 kit to mount it with. It was not necessary to cut the radio bezel as it fit over the radio. The electrical connections were made using an adaptor for power and ground with new speakers wired to the radio. The only pain was finding a wire that was controlled by the headlights for the dimming.
David are the side install brackets plastic or metal? I see this is a pocket kit just like the Metra install kit as well.
Old 06-17-2014   #12
White Bullet
White Bullet's Avatar
Sorry for the late response. But the answer to your question is it is plastic. I used the Metra kit in a 94 and the way they have the holes all over makes it very difficult to place the bracket on the side and adjust the mounting depth of the radio. The American kit is far easier to mount the bracket and allows for easy depth adjustments to flush mount the radio.
1991 ZR1, White/Red.
