02-27-2014 | #11 | |
Re: fuel sending unit and pump
Thanks. That's exactly what I was talking about. As the strainers get clogged the pump works harder. I'd suggest this could be a reason for premature pump failures.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 02-27-2014 at 01:16 PM. |
02-27-2014 | #12 |
Thanks guy's for all your help!
02-27-2014 | #13 | |
Way back when I first got the car in 97 I had pump #1 fail. The symptom is the car starts fine but will only run about 30 seconds (until the pressure drops in the rail).
02-27-2014 | #14 | |
j/k there Scott - no personal attacj, trolling, offense intended
02-27-2014 | #15 | |
Oh...wait...the LT5 is NOT modified by the switch.....so he is still OK Just some friendly ribbing What is the source of these filters? Thanks in advance I notice two different filters on fuel pumps on right and identical filters on fuel pumps on left (the black rubber clip is missing). I assume these filters on the left will not fall off? I assume both filters except the bottom one on right are kept on solely by friction fit of metal cup on the plastic? Last edited by Dynomite; 02-27-2014 at 02:16 PM. |
02-27-2014 | #16 | |
See ya later Cliff.
02-27-2014 | #17 |
Oh.....Hmmm - u started it
WE both might be seen later |
02-27-2014 | #18 | |
DO stay away from AirTech. I put one in my '98 GMC, against others' advice on GMC boards (because I keep tank FULL - which IS supposed to make a difference), and it failed post 2 years < 10k miles. Yeah - but I'm special. No, NOT special ed (as far as you know).
02-27-2014 | #19 | |
Kidding...... ha Many that have been around since the 90s know that I have MANY mods to my car. In fact I pioneered some and ALL are well documented in my FSM. To be sure all are easily removed except the Corsa exhaust. I kept the original exhaust. Again, there's nothing wrong with mods or even trashing the car if you want to. Talking others, especially newbies, into doing the same without presenting alternatives is what I have an objection to. And I sure want to be able to use "I disagree...." or for the more sensitive folks "I beg to disagree..." or "I humbly disagree...." etc. when I want to present those alternatives. It's all about respect, giving and receiving.
02-27-2014 | #20 |
OK
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-27-2014 at 04:12 PM. |
