02-09-2014 | #11 | |
Re: 1991 Zr-1 Stumbling off idle
I've been investigating this since Oct.
Marc H (an authority), says it's normal. I think time and mileage contribute to exacerbation of the 'normal' issue. Here's what I've found on mine '90, 32k; Throttle Body secondary butterflys leak air, which made elimination of problem variables more difficult. I have them temporarily blocked. This made for a rock steady idle - something necessary for diagnosis. I put in an 8mm hex bolt in the throttle stop screw hole, to make MINUTE increases in throttle, and do DataMaster readings of all parameters (I'm still learning DM navigation). Have you seen this vid? http://www.youtube.com/watch?v=ahqv0vs1Y1o It shows increases in throttle using the throttle stop bolt. Note RPM's @ 2:50, in the graph box. APPARENTLY, a transfer of control of one of the operational parameters is at fault. I'm still working on it... I suggest plugging in DataMaster, temporarily blocking the sec butterflys, and replacing the throttle stop screw, and seeing if you can duplicate DM readout. Quote:
02-09-2014 | #12 |
02-09-2014 | #13 |
Thank you all for all of the suggestions. May have a lead - car threw the check engine light today. Looks to be a code 16 (grounded pins a to b and counted flashes). Started with code 12 3x and then code 16 3x, then back to code 12. All I can find on this code is ignition 3 fuse circuit open. All fuses in kick panel on passenger side are good. Anyone have experience with this code?
02-09-2014 | #14 | |
02-09-2014 | #15 |
When I purchased my 92 it had about 52,000 miles on it, it ran rough. Found out the fuel filter was full of crap. Changed the filter, injectors, coil packs and new wires and it was a new car.
02-09-2014 | #16 |
I'm not sure what that means. Coils, wires, & or plugs maybe?
02-09-2014 | #17 |
Distributorless Ignition System or Ignition Control Module Which DIS Module is Located Under the Plenum
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-09-2014 at 04:51 PM. |
02-09-2014 | #18 | |
Is it H History, or C current? ed.: Maybe clear the code, run it to Closed Loop, and see if it sets live (Current). Do you have FSM?
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 02-09-2014 at 07:31 PM. |
02-09-2014 | #19 |
Welcome to the forum. Its great to have another ZR-1 owner in Colorado. Im sure you will find the issue with the knowlege base avalible here . Once it warms up we will have to get a Colorado meeting together.
02-09-2014 | #20 | |
Enginerd101. Be sure and check that fuel pressure from both pumps. Remove secondary fuel pump fuse. Ignition on pressure has to be about 48-55psi. Should hold steady when pump stops. Lower than 48 would be suspect. Replace fuse, repeat test. Also with engine running pressure will drop anywhere from 3-10 PSI at normal operating temps. Last edited by Franke; 02-09-2014 at 10:36 PM. |
