#11 |
That Dana Spicer [viper] gear set I believe uses a crush sleeve, not pinion shims. While you have it all torn down I would also do a cover plate drain hole. I have the 3:73 gears, wish they were the 4:10's.
#12 | |
Doing the rear will present you w a number of "while ur there" moments. Like the u-joints and rear end bushings which no doubt are pretty dried out by now. And yes install a drain bleeder for the rear end fluid. Last edited by XfireZ51; 02-02-2014 at 08:46 AM. |
#13 | |
![]() Join Date: Oct 2004
With a 13K build if you'd like to spend some more money I've an NOS housing you could use for the build with a new carrier and just slip out and use your short-axles and keep the 13K build intact. It's worth substantially more assembled with those miles than the gears by themselves. I'm not rushed to sell but if I had a 13K rear it's certainly what I'd do. If it interests you email me. The drain is a something to consider but study the options at length. |
#14 |
![]() Join Date: Oct 2013
John Smarsh has a fresh 4.10 pumpkin for sale,for $950 plus shipping. Chris Rinehart's dad did the set-up so you know it was done right.
#15 |
That would certainly be something to consider - branding of the gear set and if it were a new install or previous installed gears used might need to be considered but if it were complete with short-axles it's a reasonably priced option.
#16 |
All new parts were used,Dave. The gearset is Viper. It's just a third member/pumpkin,not axle to axle,although John does have a Dana 44 rear complete except brakes. Ratio on it is 3.45. He wants $1250 plus shipping for that rear.
#17 | |
When I mention "short-axles" I'm speaking of the left and right shafts that are retained in the differential with "snap-rings" and they're generally considered as "part of" 3d member but it would be possible for someone to offer up a build less those axles and the buyer would use his to complete it. I'd say the buy is reasonable and a person would need to question only the "clutch pack" maybe. If that were fresh I'd say it's a real good buy. |
#18 |
Sounds like its a good idea/necessary to replace the bearings as well.
I've rebuilt GM 12 bolts with the crush sleeve so I am familiar with those, but I thought the D44HD just used shims for the pinion bearing preload. What's different about the 4.10 gears that changes it to a crush sleeve? I was also thinking about replacing the original ring/bearing cap bolts with ARP bolts/studs. |
#19 | |
#20 |
All of the Viper Dana gear sets I've seen come with new ring gear bolts.
