02-03-2014 | #11 | |
Re: Valve Guide Seals
02-03-2014 | #12 |
Correction: I meant to say the valve GUIDES are what require machining to accept the seals. Fixed on my post (above). My bad.
02-03-2014 | #13 |
If your guides are not worn, then they can be removed, machined for the seal and re-installed. Because it is the same guide in the same hole doesn't necessarily mean it will be concentric with the valve seat. The valve seat may need re-cut to align properly with the valve. Not a big deal. Not unusual for the guide i.d. & o.d. to not be perfectly concentric.
As an aside, all of the new valve guides I have are configured to accept seals. New guides must have the bores reamed to fit the valves. Not a thing wrong with machining/re-using the original guides if not worn.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 02-03-2014 at 10:39 AM. |
02-03-2014 | #14 |
My 90 with 52K does not smoke at all at start up.
02-04-2014 | #15 | |
