01-30-2014 | #11 |
Re: shocks
I have had a few C4's in the past and nothing rode as hard as this. (85,88,89 and 96GS) There is some dried up oil and grime on the shocks. As original, I am sure they are toast as you say.
01-30-2014 | #12 |
Re: shocks
I will try that in the morning. Have you changed out your shocks? Anybody just go with regular shocks and remove the bulb in the DIC? If you are not driving the car that hard, is that a consideration?
01-30-2014 | #13 |
Re: shocks
Its possible, you can send them back to bilstein for a rebuild for ~200 each.
01-30-2014 | #14 |
Re: shocks
Suggest here if considering new. http://www.eshocks.com/bil_veh.asp?M...=All&SubChar=Q
$192.00 each cheapest price on the net When you turn the key to run not start do you see a service ride light ? The fx3 system only illuminates when there is a time error on one of the four corners or a problem with the controller. The time out is normally a gear or an actuator problem. However make sure the light is functional and then go from there
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-30-2014 at 10:32 PM. |
01-31-2014 | #15 | |
Re: shocks
settings? Also if you start the car either 3 or 4 times without moving it the service ride control light should illuminate. "Just to check it." I'm on the south coast towards the cape.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
02-01-2014 | #16 |
Re: shocks
My shocks are currently at Bilstein. They called the other day and told my they no longer have the rear shock rods and they are no longer available and won't be produced again. So you can only have the front shocks rebuilt now (but that won't last for too much longer).
Joe 1990 Bright Red ZR-1 #2599 |
02-01-2014 | #17 | |
Re: shocks
I guess i can see them just saying no so as to avoid people from sending them in and then finding out they were no good. I'm local, could just drop them on the back door like i did last time. |
02-01-2014 | #18 |
Re: shocks
I have turned the setting knob to all the settings several times to no avail. When starting up the light will come on for a second, then go out. I am sure the shocks are cooked, but I would be surprised if the control on top of the shocks are still good?
02-01-2014 | #19 | |
Re: shocks
From what you are saying the FX3 system is ok must be just your shocks. This is from a post on CF hope it helps ya.
