Old 12-04-2013   #11
Default Re: Rebuilding The LT5 Tensioner
Originally Posted by mgbrv8 View Post
Wow!!!! $57 bucks. But it will work.
It runs sooooo smoothly and is sooooo Bling
Our tensioners are made by Dayco. So I called them and got in contact with a wonderful guy named Randy. He verified my thoughts that the LT1 and LT4 tensioners have the same internals as our tensioner. So I ordered a new Dayco tensioner from rock auto with a discount coupon and came out to a total of $38 and it came with the pulley with the belt guides so that was handy because all you can buy right now is the smooth pulley.
Dayco 89298 No Slack Automatic Belt Tensioners
Photos provided by mgbrv8
That is some great information right there provided by David Hetrick (mgbrv8)
After the Belt Tensioner is rebuilt one can then consider the Billet Aluminum Ultra Light Belt Tensioner Pulley replacing the original black pulley.
This Belt Tensioner Pulley will fit the ZR-1 (LT5) as well as a standard C4 with L98 engine.
Ebay Billet Aluminum Belt Tensioner Pulley
See item #8 LT5 Added Systems
Old 12-05-2013   #12
mgbrv8
Dynomite Have I mentioned lately that you rock
We all know our belt tensioner's are rarer then a supermodel at a buffet. You can't find a new or old one at almost any cost so I started looking into rebuilding mine. I wanted to make sure to use basic tools with it's rebuilt so the average person could do it themselves at home. Our tensioners are made by Dayco. So I called them and got in contact with a wonderful guy named Randy. He verified my thoughts that the L98 tensioners have the same internals as our tensioner. So I ordered a new Dayco tensioner from rock auto with a discount coupon and came out to a total of $38 and it came with the pulley with the belt guides so that was handy because all you can bye right now is the smooth pulley. And I disassembled it first. The disassembly of the new unit with plastic cover is fairly straightforward the black plastic cover on the new one just pyres off with a screwdriver carefully and making sure to distribute force from one side to the other. As a safety precaution I made sure sure to wire the unit together because I wasn't sure what would happen once the plastic cover was removed I was pleased to find that it wasn't as difficult as I thought it would be and really the wire wasn't really necessary but it's a good precautionary measure. Once the plastic cover and the dampener pad and dampener spring was removed and set aside I used a chain wrench to take the tension off the stop. Once the pressure was off I could use the wooded handle of my hammer and gently tap the spring assembly back so the stop would not make contact anymore and I could unload the spring. Once the spring was unloaded all you have to do is remove the spring from the housing I did this by tapping the exposed part of the spring with a hammer and on the other side of the housing is a small hole on the back that I put a screwdriver through to tap the spring. Disassembling the old unit is only slightly different the cover which is plastic on the new one is aluminum on the old one and a litte tighter so I used a puller. I use the small quarter inch socket just a little smaller then the Center pin to press against. If you're going to use a two jaw puller make sure the jaws fit in the grooves you should be able to rent one from an auto parts store or buy one at Harbor freight and grind the jaws to fit in the groves. The rest is just replacing the old or components with the new ones. One note needs to be made though when you install the new spring use a large pair of pliers or something of the sort to compress the spring slightly to get it into the housing doesn't take much and I held the spring vertically to keep the Teflon tape from falling out.
Here is a link to all the photos of the process
https://www.facebook.com/media/set/?...1&l=bb4f436b0a
David Hetrick
Old 12-29-2013   #13
Jagdpanzer
Jagdpanzer's Avatar
Just finished up rebuilding my tensioner with help of these instructions and all went well. Thanks again David for posting this up for the benefit of the Brotherhood.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-29-2013   #14
mgbrv8
My Pleasure Jagdpanzer im so grateful it was helpful. How was the condition of all the bearings and dampener and spring?? Any pics?
Dave
Old 12-29-2013   #15
Jagdpanzer
Jagdpanzer's Avatar
Here are the parts replaced from the doner:
The finished tensioner:
The puller and insert I used to remove the cover:
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-29-2013   #16
mgbrv8
Great job wonderful work Sir
Old 12-30-2013   #17
HAWAIIZR-1's Avatar
Dave,
You are too awesome and more than any words could say. Thank you for taking the time to document this.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 12-30-2013   #18
mgbrv8
Craig thank you so much that means a lot. I just see in the future of our cars a lot of very scarce parts. And I'm use to repairing abnormal or very rare parts, right now I'm dissecting a secondary actuator to see what we can do about that when they become scarce. Thank you again for the kind words.
Dave
Old 12-30-2013   #19
HAWAIIZR-1's Avatar
There are so many smart folks like you in the Registry that help to keep this dream alive. I can only imagine the time it took you do document this and take all the photos so it is greatly appreciated. There are a lot more secrets out there, but not are all being shared like you took the time to do. I wish I could contribute like this and maybe one day a light bulb will turn on for me. Thanks again!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 12-30-2013   #20
mgbrv8
Well if there is any I am missing or don't know about let me know and I will do my best to figure it out Sir.
Dave
