Old 11-24-2013   #11
Z06scentair
Z06scentair's Avatar
Default Re: Miss after 5 min, runs great over 3000 RPM
Any update seems I may have the same situation
Z06scentair is offline   Reply With Quote
Old 11-25-2013   #12
SteelBlueZR1
Be sure you fill the spark plug boots fully to displace air with diametric grease. Hope this solves the problem.
Old 12-04-2013   #13
rollinsperf
Well, after digging the ZR1 out finally, dilectric greasing the plug boots, and test driving with no change. Misfire within a quarter mile. Taped a fuel pressure gauge to the wind shield, test drive with 50 psi all the time, with or without the misfire.
Runs great when ice cold and above 3000 rpm. The miss is coming sooner and sooner. I guess when it doesn't run at all, it'll be easier to find.
Help!
rollinsperf is offline   Reply With Quote
Old 12-04-2013   #14
Kevin
Kevin's Avatar
heat induced ecm failure?
Old 12-04-2013   #15
rollinsperf
I have been thinking overheating ECM for quite a white since I have seen it in Saturns and 1 Cadillac, but I hadn't seen anyone mention it. And since the normal flow chart answer of "test with known good part" is a little tough, I was waiting to see if anyone else has had an ECm related problem
Old 12-04-2013   #16
Schrade
You see yzpilot's thread?
http://www.zr1.net/forum/showthread.php?t=20911
Old 12-04-2013   #17
rollinsperf
Thanks for the heads up, I think I missed that one when I was looking through all the pages for answers
Old 12-13-2013   #18
rollinsperf
I drove the ZR1 with a scanner on it yesterday and found that the RH O2 sensor went to .724 and stayed there. Shut the car off, drove it a little later, same thing. New RH O2 and the car runs great, so good that after an 8 mile thrashing I could finally verify the starter hot soak problem. 3 hours later, the starter would work again.
Thanks for all the great suggestions
Old 12-13-2013   #19
Schrade
Help!
50psi all the time?
FSM says that there should be changes in static pressure, dynamic, and in response to vacuum change... UP to 4 psi drop, maybe more, IIRC here.
ed.: Yep - up to 10 psi less.
Old 12-13-2013   #20
rollinsperf
50 under a load and when it was missing, 45 at an idle and cruise
