08-17-2014 | #11 |
Re: Best Short Throw shifter?
Does Bills have a crash though reverse for a 90?
Thoughts on a crash through versus lift ring? |
08-17-2014 | #12 |
Mine's a lift-ring. I would have preferred a crash-through but forgot to discuss that detail with Bill. That said, is it really possible to change from lift-ring to crash-through just by changing the shift lever? Seems to me that functionality must be deeper down in the transmission. ?????
08-17-2014 | #13 | |
08-17-2014 | #14 |
My thoughts exactly Jerry, but I don't see one for a 90 without the lift ring. Did the 94's come with the same lift ring as my 90?
08-17-2014 | #15 |
The crash-thru doesn't have anything to do with the shifter itself... the detent pad and shift rod are different if I recall what i saw when it was explained to me. On mine, I had to pay extra to swap the 95-up ZF parts during the rebuild. I decided to do it because I didn't have the lock-out ring for use with my stock shifter. and I was used to it because my C4 previous to this one was a 95 and i liked the heavy detent.
