Old 10-31-2013   #11
rikker
Default Re: Quick/connect to T Stat housing pix
GREAT INFO: CAN I GET THESE PARTS STILL?
rikker is offline   Reply With Quote
Old 10-31-2013   #12
WVZR-1
I part numbered the retainer in my first post.
10089613 GM is the retainer # 19 in my other image and it's the same retainer that is in the connector/nipple you bought I believe from Jerry. To do it this weekend you'll need the retainer locally and you shouldn't have any trouble accomplishing that.
Like I mentioned - I don't believe I'd tamper with the female connection on the other hose. 15 - 18 aren't available (never have been). Do the retainer and move on.
Old 10-31-2013   #13
Hat's off to Dave (WVZR-1) for all his help here as well with the club in general , all ways quick to help others. Sharing very valuable information
Old 10-31-2013   #14
Schrade
Is there a divider in this cross-over???
One is thermostat controlled (P side), and the D side isn't...?
Old 10-31-2013   #15
NO
There is no divide....the flow just goes where there is least resistance.....Recycle (injector housing coolant manifolds back to water pump directly) through end of spring loaded thermostat until main thermostat opens by temperature rise.
The coolant then flows through radiator (path of least resistance) unless your revs are high....then part recycle through spring loaded end of thermostat to keep radiator pressure at acceptable levels.
See LT5 Thermostat operation
Old 11-02-2013   #16
rikker
THANKS AGAIN!!!started putting everything back together waiting on one hose from Marc H, this is such a blast to work on (JOKING) once again thanks for the help with all this.
