#11 |
If you can get that part number I'll do mine even though it's not bad so i can get detailed photos and instructions for others.
Dave |
#12 | |
1. The spring and the white insulation tape that is used between the windings. 2. The inner and outer spring guide facings. 3. The damper. The damper is the black part in the picture. 4. The pivot bushing. I say...let Marc Rebuild your Accessory Belt Tensioner for $130 including the pulley ![]() Marc Haibeck Rebuilt Belt Tensioner Or...tell Marc you do not need the pulley and use this pulley ![]() In regard to the Belt Tensioner Pulley....this Pulley has a Replaceable Bearing with a removable C-Clip ![]() See Item #9c of Bling (Carter and Others) ![]() ![]() ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-20-2013 at 05:34 PM. |
#13 |
There should be a Teflon or nylon pad in there to, to act as a dampener.
Dave |
#14 |
I thought I would respond before this thread heats up even more with all the frustration...
OK, called up Advance auto and they told me I ordered a Dayco 89298 tensioner. The tensioner has the same basic size, but the aluminum arm that you attach the ratchet to to release tension is different. Also the rear section where it fits in the slot on the engine is different. The spring inside is also installed backwards, so it is sprung in the opposite direction. The internal springs (there are 2), pulley, teflon strips, are all the same, and this is what gets swapped. Keep in mind, I am an aircraft mechanic by trade and am VERY mechanically inclined. I do 99% of all work on my cars, work on helicopters, heavy commercial aircraft, have three big Snap-On tool boxes, and am able to figure a lot of things out. I am saying this because if you ![]() My idea for this came from the ZR-1 specialist, as they offer this service, and I just put 2 and 2 together. I started looking at tensioners in the parts store for similarities. If you are not good with tools and spring loaded assemblies, I recommend you call the ZR-1 Specialist for the service. I figured that Dayco likely builds tensioners with the same internal parts to cover a wide variety of engines, and these parts are the ones that wear and will require replacement. I do not know the spring rates of the internal parts; the teflon parts inside were the same as far as I could tell, so again proceed at your own risk. I had belt squeal when I turned on my A/C so I thought this might be the problem, as the serpentine belt is new. I still get the squeal, so now either my compressor is going out or my belt just squeals from the additional load. The water pump pulley, power steering pulley felt fine and I had alternator rebuilt while I was 'going through the engine'. I figured I am chasing a ghost and now do not worry about it. When the two halves are split, the assembly snaps apart, which will have to be assembled under force while trying to line up the two halves and teflon strip that gets installed inside the winds of the spring. After it is lined up, I pressed it back together, up to the point of leaving a gap between the two major parts for movement. I don't have pictures of the process, but I hope this helps a few people out. The process described here probably is the same as the ZR-1 specialist, but once again, he knows what he is doing and has the right tools for the job. Whew. |
#15 | |
#16 |
![]() Join Date: Feb 2011
Looking forward to some kind of solution because I got one of the last new ones a couple of years ago. My original bad one isn't real bad, just sort of hangs up in its normal range of motion and doesn't tension as much as it should. It would seem to be rebuildable.
#17 | |
Very helpful thank you sir Dave |
