Old 10-10-2013   #11
Cal55
Default Re: Rear hatch weatherstripping
I've used 3M adhesive remover in the past, not on the vette though and it worked well.
Cal55 is offline   Reply With Quote
Old 10-13-2013   #12
Bob Eyres
$288? Yikes, I've got the original piece and repaired the corners once or twice. Didn't someone have a small plastic L shaped insert available at one time to re-inforce the corners with glue?
Old 10-13-2013   #13
Blownrunner
I assume you want an NCRS correct part. If not I got mine from corvette central that is less likely to split in the forward lower corner that is commonly seen. I also read that the later factory weatherstripping (from, say, 1994 on) is superior to previous years.
Blownrunner is offline   Reply With Quote
Old 10-13-2013   #14
vinsZR-1
vinsZR-1's Avatar
288.00 and worth every penny. The corners are reinforced with L shaped plastic and its GM.
vinsZR-1
vinsZR-1 is offline   Reply With Quote
Old 10-13-2013   #15
boyking
I got mine at Zip-Corvette.com for $99.00. Corners are heavily reinforced with hard L-shaped plastic.
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={282abbc4-eaad-45b3-b153-9faee883f1fc}&gid={a420e54b-cce9-4a21-8d40-9afd2d7e2d3b}&GroupName=Body+Weatherstrip&pname=84-96+Rear+Hatch+Window+Weatherstrip&Referer=&Alias=& ptct=SGR-SR&CTitle=&-corvettes.com
boyking is offline   Reply With Quote
