Old 10-07-2013   #11
Kevin
Kevin's Avatar
Default Re: another day, another code...
talked with marc and another friend and we determined that "The secondary port vacuum solenoid could have an intermittent leak. The plenum needs to be removed to replace it. The secondary vacuum check valve could be intermittent." both of these are apparently rare, what luck I have....
Old 10-07-2013   #12
If you strap the secondaries open, you can either throw in a chip that eliminates secondaries, or put in a plug to the DIFF MAP sensor harness connector so ECM is happy. Problem solved for good.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 10-07-2013   #13
Blue Flame Restorations
Before I bought my first Z, I knew that I would "rip them out" of whatever I bought. As luck would have it, Paul Denhert had already done so. Unfortunately, the other motor I used still had them, so we ripped them out as well. I just didn't want any aggrevation going forward.
Not for everyone but I never seem to hear of anyone ever putting them back in?????
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-07-2013   #14
Kevin
Kevin's Avatar
i was thinking chip + wire, but i'm on the fence. i'd like to drive a near stock car that way but I don't know anyone near by that has it done.
Old 10-07-2013   #15
Kevin this would give you a lot of piece of mind and is simple as wire and a PROM. Even if you decide to sell your car this is a selling point as you will eliminate a reason to pull the plenum in the future for a secondary vaccum issue. its also not permament and can be return to stock by simply pulling the wires and putting the stock chip back in. GC
Old 10-07-2013   #16
Good point, GC
Old 10-07-2013   #17
Schrade
Vac leaks aren't usually intermittent, are they???
I was wondering right after I got mine last year, if some circuit that's energized in Closed Loop might make such a thing happen, but no one has offered up any confirmation...
Old 10-07-2013   #18
Originally Posted by Blue Flame Restorations View Post
Good point, GC
I know his frustration a lot of us have been there. Hell my butterflies screws fell into my motor and hosed two valves and a piston.
Felt the same way after replaced my third used cat. Went to headers and High Flow Magna flows cats. There is a time you just do what you need to do.
Old 10-07-2013   #19
Kevin
Kevin's Avatar
my understanding is that the engine produces enough vacuum to keep the secondaries running under WOT and it's only when you start playing around at part, or full throttle in a high gear and low RPM that you need the extra vacuum to keep thing running. either way this requires pulling the plenum which I'm not comfortable doing.
Old 10-07-2013   #20
I used tie-wraps on the actuators. Since you're pulling the plenum anyway...
