Old 09-02-2013   #11
Default Re: 1990 Red/Red part out
Didn't the halo panels change in 91? If so these may not work for Z51Jeff
Old 09-02-2013   #12
It was 84-90,91-96.But the car being parted is a 91 and so is mine so no issues.
Old 09-02-2013   #13
But the title of this thread is 90 red/red for part out..
Old 09-03-2013   #14
I got it mixed up with the other car already parted,Damn wanted those panels.I could still use the carpet.Thanks for the info Jeff.
Old 09-03-2013   #15
emmvette
emmvette's Avatar
Are the brains any good? I may buy them for spares if the price is right. PM sent.
emmvette is offline   Reply With Quote
Old 09-03-2013   #16
icarus-54
icarus-54's Avatar
How about a back up light switch?
icarus-54 is offline   Reply With Quote
Old 09-03-2013   #17
How much for the ECM?
Old 09-03-2013   #18
dzim
I am looking for a discontinued GM part number 10052168. It is a small retainer clip (bracket) for the fuel lines on a 1994 ZR-1 Corvette. The part sits just above the blower motor control module just forward of the firewall on the passenger side. It appears to be unique for the ZR-1 model as I have not seen it on the 1994 Corvette with the LT1 engine.
Thanks,
Dale Zimmerman
1994 Black Rose ZR-1
Lincoln, Nebraska
dzim is offline   Reply With Quote
Old 09-03-2013   #19
Polo-1
Here is a starter list of part for this 1990 part out. Let me know what you all want. The car is still togather. Will not start till I have a good part of the list filled out.
Parts are all good and working. Will have pictures later as list gets filled.
Front bumper cover - 200
Front bumper support - 100
Front impact bar - 200
Hood - 400
Fender LH - 50
Fender RH - 50
Door LH - 200
Door RH - 200
Rear bumper - 1,000
Mirror LH - 45
Mirror RH - 45
All molding - 500
Rear bumper support - 100
Rear bumper impact - 100
Foglight LH - 75
Foglight RH - 75
Headlight LH - 75
Headlight RH - 75
Hood prop - 25
Front suspension - 400
Engine cradle - 100
Front calipers & brackets - 125
Dana 44 complete - 1,500
Windshield - 750 - Goldcylon
Oil cooler - 80
Oil Cooler lines - 90
Radiator - 25
Thermostat Housing - 500
Gas tank - 50
Fuel Sender - 150
Engine - 5,000 Will come complete all sensors and DIS and coils
Trans & Bell Housing- 1,000
Driveshaft - 75
C-Beam - 75
AC box underhood - 500
AC box dash - 50
Dash pad - 150
Dash skeleton - 50
Seat track LH - 50 -=Jeff=-
Seat Track RH - 50 -=Jeff=-
Seats - 600 -=Jeff=-
Trans tunnel LH - 75
Trans tunnel RH - 75
Door panel LH - 125
Door panel RH - 125
Cluster - 350
CCM & Keys - 250
ECM - 425
SeatBelts - 150 -These are post recall
Headlight switch - 40 -
FX3 & Seat Switch and harness - 150
Targa Top Clear - 350
7Targa Top Painted - 300
Inner Fender F LH - 50
Inner Fender F RH - 50
Inner Fender M LH - 25
Inner Fender M RH - 25
Inner Fender R LH - 50
Inner Fender R RH - 50
Inner Fender Rear LH - 40
Inner Fender Rear RH - 40
Tail Lamps - 50
License plate frame - 125
Reverse lights - 75 =Jeff=
AC Controller - 100
AC programmer - 250
ABS - 250
ABS Sensors Wheel 50ea -
Brake booster - 150
Brake Master - 50
Airbag - 125
Steering Wheel - 100
Column - 125
Airbag Sensors - 150
DERM - 250
FX3 actuator front - 75 ea-Cliff
FX3 actuator rear - 75 ea- Cliff
FX3 Shocks Front - 50 ea
FX3 Shocks Rear - 50 ea
Old 09-03-2013   #20
Polo-1
I might still have from the 91 part out. I need to look out in the barn. I'll let you know.
